Wow! I have just read through this entire thread. It's fantastic. I had quipped in at one point so must have been checking it out years ago but long forgotten about it since then.
Great fun watching your little car evolve! Very very sad to read about your loss too. I see you have kept on with life and seem to be doing well. I do hope you'll get bored with that little mini and crack back on with the 850! Bookmarked now :-)
Alex
Wow. 4 years and no updates.
Should I abandon this thread and start a new one or revive a thread with 20+ pages of dead pictures and out of date info?
Work has been going for quite some time now.
Brigsy
Keep this thread going. Looking forward to seeing updates.
Keep the same, add updates.
Aug 14, 2024 14:16:03 GMT
Just went thru this whole thread! Great work! I would like a 850 and do an engine swap.
teaboy
Make tea, not war.
Aug 14, 2024 16:36:58 GMT
Wow. 4 years and no updates. Should I abandon this thread and start a new one or revive a thread with 20+ pages of dead pictures and out of date info? Work has been going for quite some time now. Firstly, you should keep to this thread because multiple threads on the same car are not ideal. Second, and more importantly, please don’t make us wait another four years for the next update. Thanks.
Aug 14, 2024 20:50:51 GMT
Testing image linking. The Add picture button does not work for me so I am trying something different
teaboy
Make tea, not war.
Aug 14, 2024 20:53:29 GMT
Testing image linking. The Add picture button does not work for me so I am trying something different I can see a picture!
Aug 14, 2024 22:53:27 GMT
Apologies in advance for any random, out of order confusion to the next few posts. But here goes. In the intervening years we focused on building the business. I took time for some small projects. A BMW E28, a classic mini, a Mk1 VW caddy amongst others. I am at the point where I can get tucked into my own personal long term project. The 850 sat, quite literally on the shelf. After a while I pulled it down and built a cart for it that made a lot of sense until I did it. It turns out, as small as an 850 is, it is too tall to work on when held vertically. So I carried on with some small parts. The caliper carriers posted above are to mount the modified GSXR calipers the Fiat 124 front uprights I will be using. The calipers reshaped and had their bleeders relocated so that they might fit into 13 inch wheels The suspension geometry is based on the package I designed for the Fiat 600 chassis race cars we have built The suspension is ongoing. Expect a lot of jumping back and forth on that.
Aug 14, 2024 23:17:09 GMT
Drivetrain. I was actually quite happy with the little 843cc motors performance. The gearbox was what really let the car down. Therein lies some issues. There are exactly two manual transmissions for rear engined cars with motors that turn counter clockwise. The 850 and the Corvair. To build what I wanted in the 850 transaxle would have been prohibitively expensive. I wasted a good deal of time faffing about with an Audi 80 transaxle but abandoned that idea. Then I bought a Porsche 901 5 speed transaxle from a 68 911. Seemed like a great idea. After much handwringing about making an 850 engine spin clockwise I decided that if I was making a transmission adapter I was going all the way. Enter the Suzuki G13B Compact, lightweight, capable. So to make them work together The Suzuki swift flywheel and a Suzuki Samurai pressure plate work with a MK1 VW 190mm clutch disc which matches the splines on the input shaft of the Porsche transaxle. I didn't have enough space for the thickness of an adapter plate so decided on the path less taken At that point I could tear down the transmission for fresh bearings, seals and gaskets. Luckily the synchros are in excellent shape I modified an existing exhaust manifold. The turbo I have uses a different flange and I need top mount, not bottom The turbo is a GT1446 off an Abarth 500. So to recap. A boosted Suzuki G13b twin cam, mated to a Porsche 901 5 speed gearbox.
Aug 14, 2024 23:37:56 GMT
Aug 14, 2024 23:49:32 GMT
Some of the worst parts were in the way so away they went I was never happy with how I cut the opening for the front radiator. It was too big, the panel was rusty and... well a NOS unit was on eBay And there was an NOS fender in the Midwest to replace the one damaged when the carport fell on it But then after a lot of maths and a fair bit of screen time I have some geometry numbers for the front and rear suspension This lets me know where the pivots are located in space and I can build the front subframe around those points More hammer forming And that is enough to get me to the next stages.
Aug 14, 2024 23:56:11 GMT
A jig plate was made for the upper control arms A had some eccentric washers laser cut And machined some hardware to go with them More machining And I have an upper ball joint unit with 6mm total travel for camber adjustment And complete upper arm. The alloy arm was the first draft and one I was very happy with, but I made them out of an unsuitable material which was too fragile for a control arm so they are just nice looking scrap I invested too much time into.
And then in the spring the shell came off the jig and it was taken to be "acid dipped" Acid dipping is a bit of a misnomer. In reality the car will spend a few days to a week in a tank of caustic materials at around 120C. That does the heavy lifting and softens the paint, filler, undercoating and seam sealer which is then pressure washed away. Then it goes into an acid tank for a few hours to remove any rust. The company is very busy, this took 4 months for them to get it done. but done they got it. In the meantime I changed my role at the shop from one of day to day personnel management to being the technical director behind all the builds. This also found me moving locations. It is a smaller space, but I am making do. A few days ago I got the call that I could pick the shell up So pick it up I did I hear a lot of misinformation about what happens when you "acid dip" a shell. From it will be dripping acid, acid will be trapped eating your car from the inside out, or it will be dipped in oil. this is what I receive back from the dippers. The factory panel stampings from 1970 are still there This rear quarter is the best part of the car And the area under the rear glass is the worst. Fiat stuffed this spot with insulation batting and any condensation on the glass rolled down, soaked the insulation and started rotting the car. So back onto the jig it went. And that is pretty much where I am now. I am sure there are a ton of details I missed in trying to catch you lot up. I am trying to do at least 30 minutes of work a day. Progress isn't fast, but it is progressing
Aug 15, 2024 20:46:23 GMT
Outstanding.
Aug 15, 2024 21:46:39 GMT
I was just looking through my photos folder. The steering rack I am using is the ubiquitous Triumph Spitfire unit. Which needed to be 162mm shorter than it was so I blew it apart and cut the shaft down Cut a new thread on the end to the matching 14mm I machined an new bushing holder piece for the right side and bonded it in place with Loctite Et Viola I then went stared at the Moog online catalog for a while until I found an inner and outer tie rod that used the male M14 on the rack and was "about the right length plus a bit" so I could cut it down if need be. It turned out that the very same Suzuki Swift that the motor came out of was about as dead on as possible, so new tie rods were sourced and screwed in place. On the front lower control arms, I will be using AE86 ball joints. I am not even sure how I settled on them anymore. I tried so many. Anyway the ball joint and suspension pushrod mounting blocks are almost done Which means it is time to get the materials and finish the lower fronts. I really want to start on the rear suspension.
Aug 16, 2024 11:03:00 GMT
Bookmarked from day 1, so glad you are back at it and the ideas and craftsmanship top notch, love the hammer-formed braces and suspension arms.
Turbo'd twin cam and transaxle will be great, watching with interest!!
Got a garage now but still no car. Plenty of ideas tho!
Aug 17, 2024 17:35:19 GMT
Wow!
That is not as easy as you make it look...
eurogranada
Aug 20, 2024 19:39:48 GMT
very impressive is all I can say!
