Oct 22, 2009 12:29:57 GMT
I don't think any Lex ever had less than 16's from stock, which would suggest you can't run 15's, even with stock brakes.
15" wheels on LS400?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Oct 22, 2009 12:32:38 GMT
Is this some sort of ploy to get a set of drag radials on the back given recent events? Haven't you got a wheel you can try on?
Matt
Oct 22, 2009 12:39:24 GMT
I thought I had no 4.5" PCD 15s in the collection but I think I have some 15" Cragar unilugs I could try on there.
With a best 60' time of 2.3 sec I wondered if I could stand to lower the gearing a little as well as put some slightly stickier rubber on it. Crosses the line in 3rd as it is.
Not that I'm going to get into racing the Lexus, I just ran it as the Plymouth isn't ready and I thought it would be fun to see what it did.
@stealthstylz
Oct 22, 2009 12:58:17 GMT
It was a lot quicker than I imagined, can see the appeal of using the engines now would be easy 13s in a lighter car.
I'd just try one on. Most people are going for bigger wheels with that type of car can't imagine anybody else down sizing.
Matt
Oct 22, 2009 13:15:46 GMT
The book says 0-60 in 6.7 so I reckoned a low 15 was about right. Its still a fair result from a 2 ton saloon car with "only" 280 BHP. That motor would definitly motivate a lighter car with some fine results.
Last Edit: Oct 22, 2009 13:16:20 GMT by akku
Oct 22, 2009 13:28:23 GMT
Oct 22, 2009 13:33:09 GMT
Mine is 1999, and has the "dynamic handling package" which may include larger brakes. Mine certainly has the biggest brakes they did on an LS400 (same as the Mk4 Supra TT more or less) which makes me think that 15s probably won't go on, although I only need them on the rears, obviously.
Oct 22, 2009 14:09:26 GMT
This is a dumb question... but one I've never actually remembered to ask...
Changing wheels to a smaller size (radius/circumference)... does that make the car accelerate faster or slower???
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
Oct 22, 2009 14:12:46 GMT
as an indication of size, IIRC golf mk4 front brakes are 288mm discs with a floating caliper and 15's fit. 312mm discs with a brembo 4pot caliper needed 17's
MWF
Oct 22, 2009 14:13:23 GMT
This is a dumb question... but one I've never actually remembered to ask... Changing wheels to a smaller size (radius/circumference)... does that make the car accelerate faster or slower??? It will have no overall affect if the tyres compensate for the difference But year, smaller overall wheel+tyre diameter equals more acceleration. Some Mini's in tight sprint events went down to 8" wheels!
kee
Oct 22, 2009 14:41:26 GMT
akku, the brakes will be bigger on the front than the back, non? if so, the 16" wheels may be a minimum for the fronts, but not the rears wide 15's on the back, spacesavers on the front?
Oct 22, 2009 15:13:40 GMT
thats what I was thinking. Although mine has 17s as part of the "DHP" option/edition and may have larger brakes as well
Oct 22, 2009 16:42:59 GMT
This is a dumb question... but one I've never actually remembered to ask... Changing wheels to a smaller size (radius/circumference)... does that make the car accelerate faster or slower??? It will have no overall affect if the tyres compensate for the difference But year, smaller overall wheel+tyre diameter equals more acceleration. Some Mini's in tight sprint events went down to 8" wheels! In gear acceleration increases as a result of torque at the contact patch increasing. If the torque (force) at the contact patch is already equal or greater than the frictional force you wont be increasing the acceleration, and if it means you have to take an extra gear change then that will slow you down a little too.... its not THAT straightforward
MWF
Oct 22, 2009 17:49:54 GMT
Nothing is straight forward if you hyper theorise it. All I remember is that with Mini's you stuck smaller diameter wheels and tyres on and they accelerated faster and lost some of their top speed.
kee
Oct 22, 2009 18:02:25 GMT
acceleration is quicker as for every turn of the driveshaft, the rolling radius is shorter, same result as putting close ratio gears in. of course this is entirely dependant on achieving grip.
Oct 22, 2009 20:08:54 GMT
and I have RPM to spare at the checker board so its not a problem. Getting the 60' down is more of an issue
i owned one and worked at lexus for a year. i never saw any situation where the rear brakes were larger. and they werent that huge. the fronts though, massive units indeed.
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
15" wheels on LS400?mk14dr
@mk14dr
Club Retro Rides Member 85
I owned one and worked at lexus for a year. I never saw any situation where the rear brakes were larger. and they werent that huge. the fronts though, massive units indeed. I can't think of one road car with bigger back brakes than front, not just lexus. Even when the rear brakes are a combination of disc and built-in drum for the handbrake I can't think of an instance where the fronts are dwarfed by the rears. I do like your getting all serious about taking the beast up the strip, it shows willing
Oct 23, 2009 13:11:00 GMT
Shows willing? No, just shows I'm easily distracted...
