mason
whats the best paint stripper to use to take paint off ally wheels without damaging the metal? the wheels will be polished so i don't really want to use abrasives and i know some strippers react. any thoughts? cheers
MWF
Nitromors seems to be popular but in my experience of stripping a rocker cover with it it's messy and hardwork. Ended up bead blasting it in the end.
Nathan
Club RR Member Number: 1
STRIPPERSNathan
@bgtmidget7476
Club Retro Rides Member 1
Shot Blasting mate, I used Nitromors no end of time and its just a pain,
mason
thought about blasting ,but as the wheels are going to be mirror polished i didnt want to rough up the surface
Nathan
STRIPPERSNathan
@bgtmidget7476
Depeds upon what you ask for, I had a rocker cover done then Chromed and its perfect they will usually ask you what you are going to do with it afterwards, just state you want to mirror polish them
Last Edit: Dec 6, 2005 15:53:54 GMT by Nathan
mason
am doing it all myself (no ££££) and only have access to a blast cabinet with rough grit so its got to be the stinky messy way unfortunately
dp
DP Race Tech
mason in da house: STRIPPERSSorry but I just had to......
SteB
Nitromors works, but as mentioned, its a complete pain in the behind. Appart from being quite a potent irritant its not particularly good to inhale either!
Ive found it only really works on alloys in warm temps, and needs multiple applications - with scrapping off with a piece of plastic (old credit cards work well) in between. Its important not to scratch the alloy as that just makes the polishing harder.
We've also tried acetone to strip paint, bought 25 litres from a chemical supplier (not massively expensive - think it was about 35 quid), which was ok (still to finish the wheels we started months ago!)
Who is doing the polishing? The company that I use will do all this for you for a few extra quid
hth
Steve
slater
Club RR Member Number: 78
STRIPPERSslater
@slater
Club Retro Rides Member 78
Acid dip? i have an acid dip tank but I'm on the other side of the country
Acid dip? i have an acid dip tank but I'm on the other side of the country Really! Do you mind if i ask how big it is??
slater
STRIPPERSslater
@slater
v8 engine block size Its got stuff in it called 'carbostrip' its like a thick black acid stuff that is suppose to strip carbon off cylinderheads and exhausts but it also does a very good job of stripping paint and general crud.
Trichlorethelyne is pretty good My Polisher uses a hot trike tank to strip alloys before polishing them Not sure if thats legal anymore but it sure is effective ;D
Davenger
It's only metal
Club RR Member Number: 140
STRIPPERSDavenger
@dminifreak
Club Retro Rides Member 140
Brass wire brush works nicely. Brass isn't as agressive as steel wire brushes, so it shouldn't dig in to the ally. I use one a lot to take rust off without wrecking what's left of the chrome on stuff, works great. Just don't press too hard or it will tarnish the metal
mason
couple of hours with the stripper resulted in this pretty pleased,just not looking foreward to the polishing
looks like its come up real well! Polishing is a nightmate with a tyre still on the rim though ...
mason
tyres are off tomorrow,was going to wait to strip em once the tyres were off,but i'm not very patient
