Sept 13, 2009 19:22:02 GMT
The Chassis I have bought for the teardrop trailer project has what seems to be 4 x 140mm 13 inch wheels on. My bus which will ultimately tow it, has 5 x 205 15 inch wheels on. Can one have such wheels drilled to 4 x 140 at the factory if you get to communicate with them ? I do not want to go the adaptor route, as it adds cost, and also will push the wheels out another 30 mm or more. WHAT ALTERNATIVES Thanks for the advice.
93fxdl
Enter your message here...
Sept 13, 2009 20:02:16 GMT
I had a look here www.bikerlifestyle.co.uk/tech/pcd/pcd.html but the closest is the old beetle pcd but still no use but this is a uk chart, I did have a us chart but the law of sod says I cant find it now so there is the possibility something american may provide wheels but had a look on a couple of trailer sites and they all seem to use smaller dia pcd than that so a couple of suggestions are find the make of brakes/hub and see if they do drums with a more common pcd or is having the drums redrilled to the same as the van another option ttfn glenn found the one with yanks on it www.uk-hotrods.co.uk/v2/tech/suspension/pcd_chart.php
Last Edit: Sept 13, 2009 20:06:52 GMT by 93fxdl
Sept 14, 2009 7:13:58 GMT
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
Sept 14, 2009 8:14:20 GMT
Grizz - are the caravan wheels not the same size as one of your vehicles on the drive ?
Sept 14, 2009 8:20:33 GMT
4x5.5" odd size indeed I can't think of anything common that has that (other than caravans...)
Sept 14, 2009 8:28:16 GMT
4x5.5" odd size indeed I can't think of anything common that has that (other than caravans...) Andy beat me too it... ...you could still have them banded though!
Sept 14, 2009 8:31:00 GMT
Grizz - are the caravan wheels not the same size as one of your vehicles on the drive ? I was thinking that, but assumed he'd ruled it out.
Sept 14, 2009 8:56:49 GMT
Grizz - are the caravan wheels not the same size as one of your vehicles on the drive ? I was thinking that, but assumed he'd ruled it out. The van runs 5 x 160, not sure about Myrtle though...
Sept 14, 2009 18:10:42 GMT
Dave, bus now 5 x 205 , but you are right.
Problem is to try get something sexy.
Alternately I will have to band and get shiny caps and rings.
Sept 14, 2009 18:17:55 GMT
At a guess I would say because of the vast difference in the two pcd's you could get away with a relatively thin adapters ( say 15mm thick to keep the strength ) if you wanted to run matching wheels to the van and the price definately wouldn't break the bank PM me if you've got any questions mate .
You've been telling me you were a genius since you were seventeen ... in all the time I've known you I still don't know what you mean !
bazzateer
Imping along sans Vogue
Sept 14, 2009 19:50:55 GMT
Got the same pcd on my trailer tent I think. was hoping they would be 4 x 108 so I could put some D1s on to match the wheels I'm putting on both Madge and the Imp, but was not to be.
Sept 14, 2009 20:52:09 GMT
At a guess I would say because of the vast difference in the two pcd's you could get away with a relatively thin adapters ( say 15mm thick to keep the strength ) if you wanted to run matching wheels to the van and the price definately wouldn't break the bank PM me if you've got any questions mate . Thanks a lot, I may do, would love to have a set of Radars , the same as the bus on it. Problem will be adaptors at a sensible price to go from the 4 x 140 up to 5 x 205 .
Sept 14, 2009 21:07:53 GMT
Are you sure about the pcd, its just the trailer you purchased has what looks like an Alko chassis and they are normally 4x100 pcd. Edit: Oops, just looked at alko's website and they list 4x100 and 4x139.7, all the caravan stuff I use to move was 4x100.
Last Edit: Sept 14, 2009 21:09:47 GMT by dean36014
1992 Citroen zx
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
Sept 15, 2009 16:12:01 GMT
wouldn't it be easier to redrill the drums and use bolts ?
bazzateer
Sept 15, 2009 16:54:29 GMT
wouldn't it be easier to redrill the drums and use bolts ? Now there's a thought
rysz
Sept 15, 2009 19:58:18 GMT
wouldn't it be easier to redrill the drums and use bolts ? I had this thought on the drive home! Bizarre what I think of at times! But even the cost of having the drums / hubs re-drilled would be cheaper when you consider how much cheaper 4*100 or 4*108 wheels are! Rysz.
bazzateer
Sept 15, 2009 21:29:30 GMT
If you have them done equidistant from the originals (well you would wouldn't you? ) you can also revert to the originals any time you liked.
Sept 16, 2009 18:21:32 GMT
I think Adaptors will be the way to go.
