But every high is followed by a low, and on the way home the car over heated, the head had lifted, as I had not quite followed the Arp install torque settings correctly, a combination of duff info and bad luck.
Head was off again and sent away to be re finished, meanwhile as we had a tight deadline, the old one was fitted along with a further TRD 1.2mm metal HG
The car was running the night before the next event, at Teeside.
The car had a bad day, the timing was off and my worries about the temps saw me distracted on track, not helped by a few spins, we finished last in class.
Some good pics though, and Weston Motorsport agreed to a sponsorship deal, helping with costs no end.
With the sponsor deal in place, I took the plunge and purchased a standalone ECU, a Haltech E6X, getting rid of the restrictive standard ECU. It was not an easy install; the loom had to be custom made, as they is nothing off the shelf ready.
With the same boost level 1.0 bar we now add more power and far better drivability
Cobra Monaco S bucket seats were fitted to both hold driver the better on track and save weight, the std seats having lots of motors in it.
We used a track day at brands as a shake down
Next up was the last but one sprint off the 08 season, at Woodbridge airbase, In an effort to cure the poor braking feel; we swapped the master cylinder for a different one, hoping that would cure the problem.
On track at Woodbridge, the driving conditions were “different”
It did dry out by the end off the day
I had a bad day driving wise, not getting to grips with the course or the conditions, spinning wheels in 4th gear in a 4wd car was a new one on me.
My Existing wheels are tyres were not up to the job really, the comps are lovely wheels, but mega heavy and the yokos are really not that great on track.
So I got a set of 16” rims and painted them satin black and covered them in R888 goodness.
I had been unhappy with the ambient temps drawn un from the blitz filter, so we made up a custom cold air box.
A new gearlever from a ST185 RC was fitted, much improving the throw and speed of the change.
The Haltech ECU was re positioned in the glove box
The last race of the season was again at Teeside, but this time at night, in the wet.
We had our best race so far, 5th in class and 11th overall. Everything clicked and the car worked really well in the damp conditions, even with the R888s unscrubbed.
We finished the season with a test day at a very wet Barkston Heath, few things tried with the wet suspension set up, but the road wheels and tyres and really not great in the wet, when money allows we will go with something more suitable for the comps.
So roll on 2009.
First off was a quick service and clay off the bodywork to get rid off as much of the war wounds from last year
Then off to Rockingham, first event of 09 and first time to the track
We got a pit garage which was cool
Did not go quite to plan always!
After some rustiness in the morning session, we finished in the top 20 and decent enough class placing, but the brake prob was still evident, as was high intake temps from the FMIC pipe work routing.
So the pipe work was re done, much more efficient and less heating from the downpipe and turbo.
We also took the plunge and re did all the suspension, the prev set up was very much a fast road combination and the body roll from the springs was too much on track.
New much stiffer and lower whiteline springs were fitted, along with camber bolts for the rear, and much more neg camber introduced to the front end.
A much stiffer uprated front ARB was fitted too.
To finally sort the brakes, we upgraded to a ST185 master cylinder, which is bigger and finally has given me a decent pedal.
The car was also stripped out.
Class regs stop me taking the carpet and trim front the front out at present.
The car is significantly lower now
Using the ECU we have installed a flat shift system which is great.
Keeping the turbo spinning and stopping the revs falling to much on track
We went with high hopes to the next sprint event, but sadly this happened.
A blown intercooler causing us all manner of issues.
So we had to go for a bigger one. Which once we re mapped the car gave a further 8 bhp.
Further suspension changes saw us have a great event at Woodbridge in early August.
Future plans are to fit the rear sub frame with all new bushes along with the rear suspension. Adj rear shocks and a group A LSD rear diff of a Rally GT4
New R888s for next year and a possible engine build.
Full spec of the car is as follows.
1988 Toyota Celica ST165 UK Model
Engine Mods
Stock Gen 1 3SGTE short block
Re conditioned cylinder head
Stock cams
Steel TRD Head gasket 1.2mm
ARP head bolts
New OEM parts
Starter Motor
Water Pump
Alternator
Thermostat
New Temp sensors
New O2 sensor
New knock sensor
New Ignitor
New coil
Blue print HT leads
Re built Distributor
CT26 hybrid turbo
Aussie 3" downpipe
Mongoose 2.5" stainless steel exhaust with 4.5" slash cut tail pipe
Straight Intake
Custom sealed Cold Air box
Ali Catch can with Aeroquip hosing
Mocal 11 row Oil cooler for Power steering with Aeroquip Hosing
Mocal 16 row Oil cooler for Gearbox with Aeroquip Hosing
Aluminium Rad Tec radiator 60% more efficient
All New Water hoses
Evo 6 Injectors
Blitz SUS filter
Iridium grade 4 plugs
3 Bar Map sensor
HKS EVC 3 boost controller
Haltech E6X Ecu currently mapped to 269.5 bhp at 1.0bar boost
FMIC
2" inter cooler pipe work
Heat shielded Turbo, down pipe and air box
ST185 Drivers side Engine (mount to be fitted)
Re-newed OEM engine mounts
Stripped Out Air conditioning
Re located Battery
Varley Red Top 25 Battery
Electrical cut out switch
Gearbox and drive train
ST205 gearbox
ST205 Clutch
Fidanza Flywheel
ARP flywheel bolts
ST185 RC gear lever
ST185 RC Rear Diff with LSD Group A Xtrac internals (to be fitted)
Suspension
Front
KYB AGX adjustable inserts
Whiteline Flat out front springs
White line Anti lift Kit
Whiteline Front ARB 27mm
Tein Pillow ball top mounts
Poly bushed though out
Whiteline Front strut Brace
Rear
New Rear Shocks
Whiteline Flat out Springs
Whiteline Rear adj ARB
Poly bushed ARB
New OEM bushed sub frame
Rear Camber Bolts
Whiteline Rear Strut Brace
Brakes
Front ST185 RC callipers Newly refurbed
Pagid Front pads
Black diamond Front Grooved Discs
Goodridge Hoses
Dot 5.1 Brake Fluid
ST185 Rear discs and with ST165 Callipers and standard OEM pads
Wheels
Road Use
17" x 7.5" Compomotive MO 5 Spoke wheels in gun metal
205 40 17" Yokohama Parada 2 Tyres
Track Use
16" x 7" 7 spoke Lightweight rims painted in satin Black
215 50 16" Toyo R888 Track tyres
Lightweight Rays Wheel Nuts
Body
Sprayed in the original Super Red 2
Custom cut out bonnet with black Mesh
Custom cut out vents in front passenger wing with Black Mesh leading to cold air box
Enlarged cooling ducts in front bumper
Trim removed for FMIC
De Badged
Corona Clear side indicators, with side lights
Raybrig Clear Headlights
Clear oval side repeaters
Interior
Partially stripped rear interior
Front seats are Cobra Monaco S bucket seats in black to FIA spec
Drivers seat bolted straight to the floor
ECU mounted in the Glove Box
A pillar Mounted Boost gauge
Stainless steel dial surround
Mountney M sport Steering Wheel
Sparco drilled Pedals
Rich brock touring car Gear lever
ICE
Pioneer DP7600 Head unit
Boston 4.5 front component speakers with dash mounted Tweeters
To do list
Fit Engine mount and Rear Diff
Fit oil filter re location kit along with oil cooler
Fit Walbro 255 Fuel pump
Fit Brake stopper
Fit the following gauges
Oil pressure / oil temp
Water Temp
EGT gauge
Fuel air ratio gauge
Fit Intake temp gauge
Remap to 1.2 bar
Port and polish of Exhaust Manifold
ST162 side feed manifold with custom plugged sensors.
Replace rear shocks with AGX inserts
Cheers for reading.
