Right If any of you have ever seen one on a MGB/GT you must admit they are massive. My Question to you lot is can I just swap this out for a different one I.E. Smaller one.
I have a L Reg Civic Rad here which is small and perfect I even have the adjusted Hoses but whanted to make sure its ok to do so. I would of thougfht newer Rads would work better in dispersing the heat than one designed in the 40's.
Reason for the change (Secret) But i Need the room in the bay and this would make ample
I have probably answered my own question but hey you never know
Cheers
Nathan ;D
Cheers
Nathan ;D
