Nov 13, 2005 15:44:54 GMT
mainly the front springs on an imp......
goin hood ride on it and wanna know wht to make sure of when cutting springs......and if they need pigtailing where to?
your the only place i know that support cut springs, good lads ;D
Nov 13, 2005 15:49:58 GMT
Buy blownimps springs off him that way you still have the standard set if you don't like it or need to change back ;D
Nov 13, 2005 15:57:08 GMT
montes are nowhere near low enough.....
Nov 13, 2005 16:05:49 GMT
cant you heat them up? with a bit of pressure on them they should sag, just gotta do it accuratly. itd be a tad safer i wudda thought. although i have no major quibbles with cutting other than it doesnt stiffen
Nov 13, 2005 16:07:03 GMT
be careful though,as cutting an inch off the spring will lower more than an inch,about 1 1/2 inch from what i can remember.my bro-in-law chopped his springs down and when he jumped in it was so low it grounded with his weight on board.(oops)
slater
Club RR Member Number: 78
Cut springs..slater
@slater
Club Retro Rides Member 78
Nov 13, 2005 16:16:52 GMT
All you got to do is make them the same as they are originaly if you get what i mean. Not familar with imps but if the springs have a flat seat on them or coil tighter at the ends or basicly anything other than coil normaly then you will have alot of problems. Look here: forums.turbosport.co.uk/bbs/showpost.php?p=1119750&postcount=3If your springs are like the ones on the left you can cut them. If they are like the ones on the right don't attempt it!!
Nov 13, 2005 16:52:39 GMT
again I'm not familiar with imp springs so i couldnt say. lowered my benz by chopping them. the spring on the left is a standard front one, the one on the right is a 3 inch lowered that i had made.(doesnt look it but measured, and it is) still wasnt low enough so a couple of coils were cut to give around a 5 inch drop.then the car settled another half inch or so.used the springs off the back of my old w123 estate, which were also cut to suit. these were very easy springs to get evenly matched so it doesnt sit lop sided.i don't think id attempt chopping anything with a pigtail, and i don't think id heat them up to get them to sag.very difficult to get them both the same.
Nov 13, 2005 16:59:40 GMT
cant you heat them up? with a bit of pressure on them they should sag, just gotta do it accuratly. itd be a tad safer i wudda thought. although i have no major quibbles with cutting other than it doesnt stiffen Argh! don't do that, you will ruin the tempering, and end up with a spring which is a) mega brittle, b) completely the wrong spring rate, c) fugging useless.
Nov 13, 2005 17:08:03 GMT
Vauxhall Nova spring, cut in half...one piece in each side. I read that somewhere!
Nov 13, 2005 18:09:53 GMT
i rember reading on some forum a guy bought this car got it home and was checking under neath.....the springs were G clamped to lower it
Nov 13, 2005 18:15:36 GMT
what we tend to do with our Skoda springs is put them in a large press (10 ton), heat them up, compress them, leave them to cool, remove from press and refit
Current Fleet 2006 Skoda Roomster 1.4 16v (Daily) 1990 Autozam Revue 1.5 Auto Canvas Top (Project) 1993 VW Transporter LWB 2.4D (Camper Project) 1994 Skoda Favorit Foreman II Pick Up (Project) 1979 Skoda Estelle 120LS. (Project) 1982 Kip Kompakt 300 Caravan (Project)
Nov 13, 2005 19:34:38 GMT
put them in a large press (10 ton), where i work our smallest press isnt that "large" its 250 ton. does that not do what mr bo11ox has just described?
Nov 13, 2005 19:48:09 GMT
i rember reading on some forum a guy bought this car got it home and was checking under neath.....the springs were G clamped to lower it I don't know about G-clamps but grayston used to do a kit for either lifting or lowering a coil sping that either pulled two coils together or pushed them apart depending on which way round you put them. Basically a couple of metal blocks with bolts. I agree with Mr_B I wouldnt recommend heating springs to lower them. If you know what you are doing then thats fine if not could have very bad consequences.
Ed
Nov 13, 2005 20:27:24 GMT
measure twice, cut once ;D
slater
Cut springs..slater
@slater
Nov 13, 2005 21:06:53 GMT
What youve got to do is work out the ratio of how much you have to cut off the spring to how much you want to lower the car. It will depend on the type of suspension the car uses ofcourse. With some setups like mcpherson strut the amount you cut off the spring is pretty much a 1:1 ration with the amount the car is lowered (ignoring the camber angle) a beam axel will also be about 1:1 but if youve got something like double wishbones or trailing arms then the ration will shift in the direction of 1:2 where you have to cut less off the spring for a cirtan drop. Thats when maths lessons come in handy
Nov 13, 2005 23:28:44 GMT
measure twice, cut once ;D Then cut some more off for good measure!
Peugeot 307sw - Suzuki SV650S - MX5.
Nov 14, 2005 18:40:37 GMT
I don't know about G-clamps but grayston used to do a kit for either lifting or lowering a coil sping that either pulled two coils together or pushed them apart depending on which way round you put them. Basically a couple of metal blocks with bolts. Yup, have a set of those in original packaging - must be from the seventies I suppose. As I have a perfectly servicable grinder, they just hang on the wall in my garage for comedy value.
There is nothing more expensive than a cheap Mercedes
