looking for a tall auto shifter which floor mounts (not like Lokar which mount to the box) and I don't want some Tikki monstrosity which goes out the sun roof. mostly because I don't have a sun roof.
I was sure that Hurst used to do a long Unimatic for pickup trucks and B&M do a Megashifter with a tall base for "compact trucks" but not sure if you can still get the truck Unimatic and not sure if the B&M one is what I want.
Basically I want something which will clear a bench seat, but not hit the dash when you are in Park LOL
Ironically the Long Shifter company only does short shifters.
Anyone any thoughts?
Alistair, I normally make my own in that situation. I use an XJ shifter as a basis where you can use the cable or convert to rod and it bolts to the floor, also includes microswitche sif you box doesn't have an inhibitor as stock .
Lock outs are achieved, as standard , by pulling the shifter towards you rather than any push /lift buttons . Section the original XJ shifter and bolt / weld your new shifter to it. Thats how I'm using a old 60's Hurst manual shifter on the C3 in the POS. I've a photo if you want it but can't put it up here .
Similar design on some mk3 granada autos too - I have one here that has pull to lockout, easy to lengthen, threaded same as a ford manual stick at the top. It's in the "might be useful someday" pile, lol.
only one i can think of is mk2/3 transit.
theres more to life than mpg & to much power is just enough.
hard to find maybe, but Bay window/T3 Kombi?
Remade In Australia thereimaginarium.com.au
Hmmm... some interesting suggestions. Kev if you would like to email your pics I think you have my email address?
colum shift! column shift!
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
I have a column shift but its falling apart. I was going to junk it and replace it with a floor shifter. Means I have space for headers too then.
redo linkages on column shift, maybe even use a cable, sorted
I have made an attempt using some "improvisation". Its not great. If I could get a poly bush to turn down (maybe an ARB one or something) for the main selector shaft it would improve matters.
