;D Just a quick update, Look what I have just done a deal on With 60,000 miles on it and a Knocking bottom end, so it wants a set of rings and some investigation and bearings finding for it. Everyone says you cant rebuild them but I cant find anything at work that makes them special So £30 well spent I feel ;D ;D Got a set of R1 throttle bodies in the garage as well Got some more bits to take photos of as well ;D
sweet as geez! wudent mind something like that for myself!
although, for the work thats gonna invlove getting it in tehre, why not go 2.0 zetec?
sweet as geez! wudent mind something like that for myself! although, for the work thats gonna invlove getting it in there, why not go 2.0 zetec? I want to stay below 1400cc I want a lightweight Screamer, with cheap tax ;D 120ish HP in a lightweight reliable package should be plenty. This is all Alloy as well without the Iron block of the Zetec. If I do need more then it will be supercharged, so I still keep cheap tax And worst ways, the 1700cc from the puma is dimensionally the same, so I can drop one of those in instead ;D
sweet! i wanna build a revvy 1300 crossflow at some point in my life, but a big power cossie will be first on my list ;D ;D
wow, what a result - cheaper than a night out down the pub!!! when is it likely to find its way into the kadett mate?
they're a curse word for disintegrating when you run 'em low on oil. they are rebuildable though, i know a chap who gota recon one for his fiesta when his original started knocking badly. pretty good tunability, nice light engine - not as hardcore as 2.0 but slightly more modern and same tuning process applies.
Yea, the bottom ends on those go a lot. I can only hope you manage to find the bits you need, I hope they're not too dear from the dealers!
I do have access to........... how should I put this Insider information Its only an Engine, they all do the same basic things, if I can get Bearings it will be rebuilt, I don't think they are available from dealers, but I might be able to get them direct from the Plant ;D What happens is the Oil control rings wear, then they burn oil, run low and knock out the Big end bearings The second generation did not have the same problem because the ring material was changed As for when it will end up in the KAdett depends on when I can get everything to rebuild it. For now, I have the Ex Nightmares 1.2s motor and gearbox to go in along with the twin carb setup. I want to change the gaskets before fitting it, then I can get the Zetec stripped Some more Bits that arrived from Germany ;D Koni Adjustables for the front Manta 400 Mirrors ;D I`ll get some more Bodywork pics tomorrow in Daylight ;D I have also replaced the rear Dampers with Nova GSI Rears, and fitted the old front springs on the rear with 2.5 coils cut out..... rides a lot better now, but still wants to go stiffer and lower on the rear. I have some new ARB Drop links to go on the front as well, so it may not look very much but progress is continuing ;D
I do have access to........... how should I put this Insider information Been talking to a bloke down the pub? Paint them yourself?
ILIKELURKINGME
I do have access to........... how should I put this Insider information Been talking to a bloke down the pub? Paint them yourself? HARHARHAR What you been up to then slowbloke You coming round tomorrow ? Moto GP on Eurosport Hows ben ? cowering in the corner
might be able to sort you some rings and bearings
how old is the motor??
2001 HONDA CT110 (NOT RCV)
Interesting engine choice. A bit of cross polination can be a good thing I would have expected an Eco-tec but that would have been a bit obvious I suppose. What box will you use with the Zetec, a Type 9? Englemanns eh? Hmm, good choice sir
ILIKELURKINGME
HARHARHAR What you been up to then slowbloke You coming round tomorrow ? Moto GP on Eurosport Hows ben ? cowering in the corner Hmmmn Was there supossed to be something there
HHHMMMMM...seems like I've got trigger finger! managed to post that reply without even writing anything ;D Not been doing much as usual,just surfing round deciding on all the cars I'm gonna get ::)and what I'm gonna do to them .VW Polos have been todays weapon of choice. Will give you a ring in the morning about coming over for tea and cake ;D Ben has been staring at the carpet with radar ears and eyes. I keep thinking I hear your Camel Kadett going past,.............. must be the bangers.
ILIKELURKINGME
Interesting engine choice. A bit of cross polination can be a good thing I would have expected an Eco-tec but that would have been a bit obvious I suppose. What box will you use with the Zetec, a Type 9? Englemanns eh? Hmm, good choice sir Have you seen the price of 1800 manta bits lately I can buy an ecu for it and a type 9 for less money than a Manta sump and 5 speed to fit an XE Zetec is lighter than XE as well
HHHMMMMM...seems like I've got trigger finger! managed to post that reply without even writing anything ;D. EDIT: Thats what spending 3 months surfing those other "Rides" sites does to you You need to get back out in that garage again and away from your "favorites"
Last Edit: Nov 8, 2005 8:09:25 GMT by CR500Dom
might be able to sort you some rings and bearings how old is the motor?? Sorry Hairnet, I missed this in amogst the Pi**takes ;D I will find out today what age it is, be excellent if you do have a source for them Cheers Dom EDIT: Its 1997, 07/08/97 to be exact ;D Cheers D
Last Edit: Nov 8, 2005 14:04:51 GMT by CR500Dom
