nizzer
Jul 16, 2009 22:12:58 GMT
based in Doncaster
2.0 pinto engine good condition running 100% when removed from my escort. no sump or ancillaries £50
Pinto efi setup. inlet with throttlebody, wiring loom and ecu, airflow meter all there. set up with different injectors for pinto turbo. £80 posted
Transit starter motor, looks pretty recent. off a 2.5d engine. £40
2.0 pinto bottom end £15
good 2.0 pinto head with knackered cam £20
cheers.
Last Edit: Jul 28, 2009 12:45:11 GMT by nizzer
cortinadale
luvvly jubbly!!!!
2 litre or 1600 engine??
We learned from an early age that...people who change signatures suck balls ;-) 1978 Cortina 2.3 ghia
nizzer
sorry forgot to say its a 2.0.
Jul 20, 2009 21:10:20 GMT
is this a turbo ecu??? how will this cope with the turbo??? has it been tried out
Drive it like you stole it
nizzer
Jul 21, 2009 19:57:42 GMT
Pm sent
cheers
nizzer
Jul 23, 2009 23:35:58 GMT
bump.
nizzer
Jul 28, 2009 12:43:57 GMT
bump also pinto bottom end from sierra £15
deejay
WELSH DRAGGIN'
Jul 28, 2009 15:51:04 GMT
Pics of engine and injection please mate? Is the pinto a 205 block? As above really how does it manage the boost?
nizzer
Jul 28, 2009 17:05:39 GMT
engine is non 205 block and is separate to the efi. was given the efi in part ex for some dellortos i was selling. fuelling is done by cosworth dark blue injectors and the airflow meter is tweaked to supply mroe fuel on boost I'm told. ive never run this setup so don't really know much about it but there is mountains of information on turbo pintos and this setup on turbosport.
