Oct 28, 2005 16:11:51 GMT
right guys, like retro cars, whats your favourite 10 (low-ish) cost retro mods you can do to make your standard retro motor stand out from the crowd? mine would be in no order: 1.sorted suspension 2. 4 cibie oscars 3. 7x13 superlites/revo's/ etc 4. 4 branch 5. twin sidedraught carbs ;D 6. brake conversion 7. CB always ;D 8. ACE black/silver plates 9. performance cam 10. half cage
Why you always bring me junk!
Oct 28, 2005 16:19:37 GMT
1) Different wheels, sometimes off a higher model 2) Nicer steering wheel 3) More gauges! "Capn', she cannae take it!" 4) Subtle engine mods, like eleccy fans, filters, electronic ignition etc 5) Sports exhaust 6) Sorted suspension 7) V8, of course! 8) Screaming 4 pot....can be done cheap! (relatively) 9) Let the light in, via a full length webasto! 10) Decent brakes/steering.
Better get to work, methinks!
Mr K
Oct 28, 2005 16:47:13 GMT
in no order: 1. detailed wheels... somthing 70s with deep dish n euro tyres 2. 70s spot lamps 3. a hitting with the stick 4. fat carbs 5. roof rack 6. 70s harnesses 7. sports exhaust 8. supercharger 9. nice little retro steering wheel 10. stickers.... / old skool decals (espcially full length side ones) its a good formula for retro cool
Oct 28, 2005 17:07:46 GMT
in no order... 1, sticked to death 2, tassles 3, mirrors 4, tigerskin 5, chainlink wheel 6, uv/ flashing tat 7, red oxide 8, alternative wheels 9, sports slats 10, more stick
Oct 28, 2005 17:10:31 GMT
1 - turbo 2 - supercharger 3 - mid mount that suka 4 - Big brakes 5 - wide arches 6 - split rims small and wide 7 - stripped interior 8 - buckets on the floor 9 - harnesses 10 - gauges
in no real order, even all at once!
J
slater
Club RR Member Number: 78
your ten best retro mods?slater
@slater
Club Retro Rides Member 78
Oct 28, 2005 19:58:07 GMT
1. Sort the stance (normaly low but could be high or rake if if that way inclined!) 2. Sort the wheels (normaly wide, big offset with stretched rubber) 3. Sort the paint (matt is good and very easy but its been done so try themed such as green and with yellow stripe John Deer style!) 4. Roof rack (with something on it (not a coolbox thats oldhat and ghey) try a tractor tyre ) 5. Random accessory such as racer86s old roofrack mounted light! 6. Debumper or fit oldskool chrome version 7. Side exit exhaust (matt black) with a upswept kink on the end about 6in long 8. Strip interior and fit glass buckets upholstered in a old skool fabric 9. Fit bike engine (or simlar unusal power plant) 10. Fit Fully adustible, rosejointed coilover suspension setup I think about this stuff way too much
Oct 28, 2005 20:29:35 GMT
You need ten? 1) drop it to the bump stops 2) apply suitable wheels 3) drive....
Oct 29, 2005 11:38:39 GMT
1. Slam it 2. cool wheels 3. Cibies 4. Black bonnet 5. de badge and trim 6. Cherry bomb exhaust 7. Drive it ;D ;D ;D
Oct 29, 2005 16:36:32 GMT
In no particular order of preference;
1. Slam 2. Wheels 3. Fruity exhaust 4. Throaty carbs 5. Sraight cut gears 6. Period steering wheel 7. Non UK spec part or accessory (eg, US spec lights) 8. Lumpy cam 9. Webasto roof 10. Cibies (if it's a rally slag)
Oct 29, 2005 17:09:25 GMT
subtly stroked with the stick 5 bolt wheels half cage vinyl sports seatage 2.5 inj motah ;D billies
2001 HONDA CT110 (NOT RCV)
The following is what I have done and still do. Also the list doesn't work out that expensive which to me is what it's all about 1. Cibie Oscar ('Chrome rim', 'plus' or 'super' etc.) Spotlights (This is proving the most popular on this thread ;D) or if an 80's vehicle some Hellas can also look good/ 2. Retro Steering wheel with alloy spokes with holes 3. Chromed (if steel) or highly polished (if alloy) rocker cover. 4. Super Clean engine compartment 5. Plenty of dials on dashboard (make that 70's 'E' Ford Jealous ;D) 6. Aftermarket wheels (Revolution or Wantanabes are ultimate if money will permit) or rostyle etc wheels of higher model in range. 7. Tyres such as Yokohama (the A008 with the 1/3rd 'banded' edge with holes in were best) also liked the Original Goodyear NCT (Not 'Eagle' NCT) range. 8. Sump guard. 9. Polished up rear exhaust 'back box' (but no silly sounding 'chav' back box). 10. A few 'Classic' stickers under bonnet and in/on side rear windows. The whole list above (apart from the fittment of Revolution or Wantanabees) can be done to a vehicle for less than £450 and thats if buying new!
Oct 31, 2005 10:25:25 GMT
well, the original post said "to make stand out from the crowd", and you've all said pretty much the same thing (I'm surprised i havent seen HW and the words "outside the box" yet! ) so i say ..... paint it pink and fit one of those air horns from a ferry!! ;D
Oct 31, 2005 11:12:45 GMT
Round were I live in Telford that would make it stand out due to all the boring Chav Saxo's and Corsas about (ice lights, big bore exhaust and Badly slapped on 17inch wheels which bang the arches :
