Jul 12, 2009 11:29:26 GMT
First lot were made by my dad, and passed on to me over the years... Slide hammer, the weight is from an old yarn winding machine... Deep clamp, for reaching over sills when welding patches into floors... Cradle for one man removal/refitting of RWD gearboxes, replaces saddle on trolley jack. Plate is part of an old lawnmower... Ramps...! Coil spring compressors... Clutch aligning tool... Ford Pinto engine valve clearance adjusting spanner... These are some that I've made over the years... not quite in the same league... Rover 216 front pulley locking tool... Tack lifter modified to re-fit Vauxhall (IIRC) clutch cable return spring to the pedal... Carlton gearbox filler plug tool... Erm... 'things' to extend the reach of a hub puller...
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
lae
Homemade toolslae
@frinkmakesyouthink
Jul 12, 2009 12:55:51 GMT
Home made tools are the signs of a proper mechanic!
Those spring compressors look far better than any I've seen for sale...
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
sowen
Club RR Member Number: 24
Homemade toolssowen
@sowen
Club Retro Rides Member 24
Jul 12, 2009 14:47:57 GMT
I've made / modified a fair few tools in the past. Making serpentine tensioner spanners is a popular one. I have a drawer of spanners all ground down at work for stupid fiddly jobs in tight spaces.
Homemade toolsBenzBoy
@benzboy
Club Retro Rides Member 7
Jul 12, 2009 19:19:03 GMT
I've got a collection of busted sockets / spanners / other stuff just for adapting! ;D I'm jealous of that deep clamp... excellent!
Homemade toolsDeleted
@Deleted
Jul 15, 2009 19:43:46 GMT
Making tools is what distinguishes us from animals
Jul 17, 2009 12:01:11 GMT
Just remembered a couple of others that my dad made... when a moped tw@tted the front wing of his Vanden Plas 1300, he flame cut 2 plate steel rings, welded a 'U' shape plate to one, bolted them into the headlight aperture, chained the 'U' to a fencepost and reversed the car to pull the damage out... ;D
He also made a roller thing to sit the front wheel of a Maxi in so he could run it up in gear to diagnose a noise on the front.
slater
Club RR Member Number: 78
Homemade toolsslater
@slater
Club Retro Rides Member 78
Jul 20, 2009 22:20:52 GMT
I'm going to have to get the camera out, id need a whole forum!
ant318
Jul 21, 2009 21:23:23 GMT
homemade tools rock and as for ground down spanners my mate laughs each time i pull out the 2" long 12mm spanner that i use to remove the oil feed from the otherhalves supra turbo ive still to this day never replaced it ;D
Jul 26, 2009 20:17:23 GMT
Homemade rocks Between me and my rallying mate we've made an engine crane, tyre changer, 5 tonne benchpress, chassis straightener (using a 5 tonne jack!), and a massive A fame (originally for lifting our boat, but very useful for lifting the front of the rally car high up in the air to fit things like sump guards!).
Jul 26, 2009 20:18:39 GMT
Damn! How about that? In the few second it took me to type that post, Ant managed to use the same opening expression.
Jul 26, 2009 23:14:57 GMT
Part toothpaste filling machine - I present my wheel cutting jig for banding steels.
slater
@slater
Jul 27, 2009 18:34:53 GMT
i like that!
Jul 27, 2009 20:00:36 GMT
^^^^ loving that... do you have a welding jig too??
