The Ecsta DX Aroma is Kumho's Grand Touring Summer tire designed for trend-setting, fashion-conscious drivers who enjoy products that will set their luxury coupes and sedans apart from everyone else's. In addition to delivering an alluring aroma that replaces a tire's normal rubber smell with the subtle scent of fresh lavender, the Ecsta DX Aroma is designed to deliver a comfortable ride and low noise, while blending dry and wet traction with good wear.
Using a special mixing technology to blend the fragrant oils into the rubber compound, these heat-resistant oils are said to enhance the bonding of rubber chains and maximize the viscoelasticity of the rubber compound, which helps reduce braking distances on wet or dry roads. The Ecsta DX Aroma compound also features silica to improve wet traction.
This unique compound is molded into a sophisticated directional tread design that features a continuous center rib for constant road contact to enhance highway stability, along with tread blocks designed to provide uniform stiffness and maintain ride comfort throughout the life of the tire. The tread blocks also feature an optimized pitch sequence resulting in variable pitch lengths to help minimize noise, while four wide, circumferential and numerous sweeping intermediate grooves help evacuate water reducing the risk of hydroplaning. The tire's structure includes high-tensile steel belts and a jointless nylon cap ply to help improve ride comfort and durability, while an undertread reduces unwanted heat buildup for consistent performance.
NOTE: The lavender scent lasts for about 1 year and while always present, is most noticeable immediately after normal driving when the tires are warm.
www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Ecsta+DX+Aroma
