Getting rid of a lot of my stuff that I'll never need again:
5 x 5 stud Starion wide body alloys - rears have new tyres, two will need new (slow deflation and old!), one is fine. Fits Toyotas - £150
2.0 4G63 engine - complete with turbo, inlet, power steering pump, and everything else, comes with ECU which I changed as I thought it was messing around somewhere - £150
Turbo cross pipe with factory BOV extension - these are quite rare, it's the metal pipe from the throttle body to the pipe to the intercooler, but it comes with a little outlet pipe for blow off valve - £20
Turbo downpipe - pipe from turbo to exhaust - £10
E101 Knock sensors - £15 each
MAP sensors - £15 each
Pair o injectors - £20 - one is 1000cc and the other is 800cc (I think)
Coolant Temp Sensor - Cost 50 quid new, never used, £25
Loads more stuff if you're interested.
