Jun 28, 2009 12:27:00 GMT
There's beer with your name on it if someone around glasgow can help me with a little welding job. I bought a Chrysler Neon (RT) as a fixer upper and it had a bit of accident damage on the back of the sill. I've pulled the dent out with a slide hammer, which meant drilling a couple of holes in it. Now I could just fill it with liquid metal and bosh some filler on it but I'd rather get them welded up and do it properly. The problem is I don't have a welder or know how to weld. It's all prepared and the holes are maybe 5mm across below the rear door. Here's the shed in question.
purplevanman
Way too orangey for crows
Jun 28, 2009 21:43:45 GMT
A good dollop of primer first and then a bit of filler, would probably do less damage than welding! do i get a beer now?
Jun 28, 2009 21:56:07 GMT
lead solder it the old school way .don't weld it will make a right mess can i share the stella with grunty
Jun 28, 2009 22:21:38 GMT
I was going to fill the holes with liquid metal then filler over it but I thought welding it up would be better. Maybe I'm better going with liquid metal if the weldings going to be messy. Here ye' go
purplevanman
Slurrrrrrp, ahhhhh cheers Welding would burn any protection off the inside, its not rusty so wont get any worse, prime (get it right in the holes) fill and paint
as siad lead fill the holes rather than welding, but for future refernece, I'm in kilmarnock and have a decent welding plant here for use
as siad lead fill the holes rather than welding, but for future refernece, I'm in kilmarnock and have a decent welding plant here for use Cheers. It's always good to know someone with a welder near by.
anytime, I'm not a very good welder atm, but going to be learning soon and should have my coding in a year
I'm just down the road in troon. What do you drive and i'll keep an eye open for you? I've thought about buying a welder but it would just encourage me to buy a rustier car to have something to weld.
Right now just a 2.0 mondeo but its a good workhorse, trying to get the skoda in the for sale section, but its just trying to get it delvered etc
Give this site a go. It's like a reverse ebay for delivery. You put in were you want the car to be picked up and were you want it delivered to then various delivery companies/mans in vans bid for your business. It takes a few days for the low bids to come in but I was looking to bring up a mk1 Cav from down south a while back and the price I ended up with was very reasonable. I didn't end up buying the car though. www.shiply.com/
been looking at prices on there mate, tbh it just doesnt make it viable, i was looking for a cheap retro to work on, but would double the cost of the car, but thanks
