This morning, I walk out the house, get in the Lupo and turn the key. Nothing. I turn it again Nothing. ![???](//storage.proboards.com/forum/images/smiley/huh.png) Then I remember that I took the engine out last week, slap my head and walk down the drive to my borrowed 106 Another one from a few months ago, when I serviced my mums Ka. I dropped the oil, and in removing the sump plug, it landed in some dusty gravel. I put it on the wall for safe keeping, removed the oil filter (easier said than done on a Ka) and fitted the new one. Then I proceeded to pour 3 litres of 5w30 in, while looking at the sump plug thinking "I must give that a wipe before it goes back in" I check the dipstick - nothing, so pour another litre in before realising my mistake. I'm normally not a complete moron.
the first one fair enuff the second##lmfao
2001 HONDA CT110 (NOT RCV)
kee
haha, made me laugh.
when i changed the head a couple of weeks back i started it up and ran it for 20 seconds, then thought to myself,
'I hope i've done this right and it doesn't start getting too hot, oh ****, not put any water in yet'
also forgot to tighten my wheel bolts too many times
also forgot to tighten my wheel bolts too many times This is something I've never done.* *this may be a lie.
Jun 17, 2009 10:18:46 GMT
got in wrong/identical car in car park if that helps nowadays mod em so much there aint another like it to confuse me standard spec aint in my vocabulary anymore
jikovron
mechanical chaos
Jun 17, 2009 12:17:09 GMT
ahh i have this problem now and again ![:-[](//storage.proboards.com/forum/images/smiley/embarrassed.png) leaving the car running,,,and slamming the locked door shut while i check for something ive forgotten going to a mot test with no wiring connected to the rear lights oohh,fitting a 1.1 litre renualt 5 c1g engine to my old 340 thinking it was a 1.4 c1j forgetting to tighten the prop clamp bolt on the 340 and it flailing all over the underside in the middle of northumberland starting the engine with a 30mm socket and ratchet handle attached to it ,,,rear engined so my dad wasnt amused about it flying out the back while he was pushing it ![:o](//storage.proboards.com/forum/images/smiley/shocked.png)
sparko
Jun 17, 2009 12:36:15 GMT
by buddy was showing us his delocked mk1 astra (xe on bike carbs yummy yum) and the door closed while the keys were in it. yup one set of keys, the car running and a good half a tank of petrol in it lol. its amazing how you think like a criminal if you have to break into your own car ;D
Jun 17, 2009 12:42:33 GMT
Tried for about 5 min to start a car i'd removed the king lead from.
Started engine with no rocker cover
Left socket on crank pully and started engine
Left locking wheel key on one of the nuts and drove off (lucky it fell off at the end of the drive and got found about a month later (3 days after i'd paid £20 to have the set removed because i'd lost the key ;D )
eddbmxdude
Yeah, its a turbo!
Jun 17, 2009 12:45:10 GMT
Forgot to do the tensioner up after I had fitted a twin cam head on my metro. After driving it to work I took a look and the cam belt was halfway off the pulleys. "What the.......ohhhhhhhh!"
Old skool cool!
Signature image maximum height: 80 pixels
Jun 17, 2009 13:10:31 GMT
1) Towed my 'spares' B310 Sunny down the road to a new address, forgetting to do up the wheel nuts after robbing the front brake discs for my daily B310 (yes, I was a skint student, and spare B310s was cheaper than a new set of discs!). Anyway, a couple of hundred yeards down the road, there's a bang and the car lurches as front wheel disembarkes from the towed car, rolls serenely passed me, and into the front garden where a poor chap was cutting his grass.
2) Same 'spares' B310 needed to be moved from the car park as the council were getting anooyed by the eyesore. No-one around to help me push it, so instead I chucked the battery in from my daily, and set about driving it round the back next to the garages. However, after being stood a good couple of month, the rear drums were stuck on, so judicious use of the throttle in reverse was needed to 'break free', whereupon the Sunny shot backwards across the carpark to a row of neighbours cars. Applying the brakes did nothing (remember the aforementioned 'theft' of the brake discs for my daily?), so instead selected 'DRIVE' (did I mention it was an auto?) so that instead of shooting backwards, I shot forwards, panicked, and drove straight through a brick wall.
sparko
Jun 17, 2009 13:18:59 GMT
^^^^ ha ha ha ha ha ha thats class!
Stupid Forgetfulness?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Jun 17, 2009 13:37:45 GMT
My mum and dads drive is on a steep downhill slope. When I was changing the oil on my old 106 I had it up on ramps to get the drain plug out. Dropped the oil, put the new filter on and put the sump plug back in. Then I stupidly though "damn it needs to be level to fill it to the right level" so I jumped in, fired it up and reversed off the ramps onto the street lol.
Matt
billy
Jun 17, 2009 13:39:08 GMT
when I was a 16 year old yts mechanic I forgot that we had not got an oil filter in stock for a v6 transit serving ambulance that I was serviceing untill it was fired up and the oil light wouldnt go out I found the cause when I stumbled accros a dirty great oil slick on the garage floor
Last Edit: Jun 17, 2009 13:39:47 GMT by billy
purplevanman
Way too orangey for crows
Jun 17, 2009 18:34:57 GMT
Thanks guys, I needed cheering up ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Jun 17, 2009 18:51:24 GMT
Not my own forgetfulness, but the garage who changed a split steering rack boot on the fiorino for the mot. Seems that not only had the guy forgot to put the speedo cable back in (taken out for better access, so we quickly put it back in), he had also forgotten where he had put his tools. this was found a month later ;D ![](http://i2.photobucket.com/albums/y30/merc-owner/SP_A0789.jpg)
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
Jun 17, 2009 19:34:44 GMT
My other half threw a couple of slices of bread in the tumble dryer one morning a few months back and got all confused at why her toast wasnt cooking... perhaps it's your hormones matey?
Porsche 924 - gone Citroen Saxo VTR - not very retro but I loved it - now gone... MK4 Golf GTi 1.8T - gone but hardly remembered... Mini Cooper S R53 - gone BMW 125d Coupe - gone (mostly sideways)
Ford Focus RS Mk1 - hello low MPGs and "wanna race me" at every set of lights... 1973 BMW 2002 - Twin 40's, 284 Cam, Revolutions, E21 Recaros + more Porsche Cayman 987 3.4S - here and due to cost me more money than I have
billy
Jun 17, 2009 19:54:45 GMT
Not my own forgetfulness, but the garage who changed a split steering rack boot on the fiorino for the mot. Seems that not only had the guy forgot to put the speedo cable back in (taken out for better access, and quickly put back in), he had also forgotten where he had put his tools. this was found a month later ;D ![](http://i2.photobucket.com/albums/y30/merc-owner/SP_A0789.jpg) I can beat that but it wasnt me it was my workmate ![;)](//storage.proboards.com/forum/images/smiley/wink.png) we had a pug 405 fail on a shocker and my mate used mole grips on a nut 12months later it took us 20 minutes to remove the mole grips when we found them at mot time ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Jun 17, 2009 20:19:32 GMT
i've forgotten where I've put the nuts for the flywheel cover/starter motor plate for my austin 7. not really a problem except I'm racing on saturday, and I don't know where I can buy a 17mm nut with BSF thread...
Jun 17, 2009 20:39:06 GMT
I forgot a large caravan I had purchased the day before was quite tall. I drove it into a height-restricted (but completely outdoor) car park. I removed about 50% of the roof
*Forgot* about polarity and connected a battery back-to-front and fried a £2000 dash display
Changed the oil in a car but forgot to refill with oil. Fired it up and it was noisy so left it running and went to find a second opinion - it survived OK
Changed the oil in a manual gearbox. Went for a drive and remembered I hadn't refilled it either when it started getting noisy - it survived OK
All a long time ago
orangecords
yawner extraordinaire
my mate chopped his index finger off at the first knuckle forgetting that its a fixed fan on a 2.8i capri not a viscous one like on his escort..... "watch this" was uttered before he did it and he never forund the end of his finger!
not funny then but almost amusing now!!
I then wanted to start cleaning the interior as it stinks of wood (the material not the smell of a boner) best quote ever!
