these are some american lattice style alloys. not sure what they are off, but surplus to my requirements. pcd is 5x130 - rough measurement centre bore is roughly 95mm just need a refurb but certainly not knackered looking for £60. collection from warwick or b'ham
slammed 66
www.gtturbo.org
They're not 5x127 pcd rover sd1 vitesse alloys are they?
86 Renault 5 GT Turbo 89 Renault extra 91 Skyline GTR 98 Mini 1275 mpi 99 Autech Rider www.gtturbo.org
could be - look very similar but the centre bore is different. sd1 alloys have a raised bit in the middle. twin plenum alloys are 6.5x15 I think?
alloys are stamped "made in america" and "A.R.E"
some jeeps are 5x127 pcd
lots of chevys are 5x127 so best bet
Jun 10, 2009 14:07:36 GMT
5x130 is (from memory, so don't quote me!) Porsche, Mercedes Sprinter van and Honda S800. All of those options seem unlikely to me. ;D
Jun 10, 2009 20:05:27 GMT
if they are 5" PCD (which is roughly what 127mm comes out as IIRC) then they will fit 1990s Jeep Grand Cherokee, Buick full size, Cadillac, Oldsmobile full size, and some Chevy station wagons with the heavy duty axle option. They also fit Lincoln full size, early 70s Ford LTD and Custom, and 1960s Imperials on the D body platform. If the offset works they will also go on Rover SD1, P6, P5, P4, Commer vans, Humber Hawk, Super Snipe, etc. and Austin Westminster.
Most Chevy and Pontiac are 4.75" which is closer to 121mm (as are Buick and Oldsmoble compact, G body and the like).
Almost all Jeeps are 4.5" (114.3mm) except those with military style 6 lug hubs and the 1990s Grand Cherokee as above.
I'm trying not to be tempted by these LOL.
Last Edit: Jun 10, 2009 20:07:43 GMT by akku
they are definately not 5x114.3 - can confirm they are 5x127.
can try to get more measurements and pics if anyone wants?
5x127 = Cortina P100 and Sherpa van too?
Jun 11, 2009 13:57:22 GMT
indeed, you are correct as always. Plus Chevy Astro and GMC Safari.
Being yank in origin they will have the larger centre bore so should fit pretty much anything (with spiggot ring if required) whereas the UK sourced 5" PCD wheels usually don't have a big enough centre bore to fit the yank cars.
A.R.E. is American Racing Equipment.
I like 'em but they'd look gash on any of mine.
changed title to 5x127 pcd
sowen
Club RR Member Number: 24
Could you measure the distance from the back of the hub to the outer rim please? I think they'd work on my p6 if they'll fit.
Jun 15, 2009 13:24:17 GMT
will do - expect a post on here around 6pm today
Jun 15, 2009 18:27:09 GMT
The distance from the rear of the hub to the rear rim edge is 96mm.
sowen
Jun 15, 2009 19:40:26 GMT
Thanks for that, but I can't use them as they've got too much offset.
Good luck selling them though.
provisionally sold to mr stuyizz
