Anyone know if I need any special tools to replace the discs / pads on my MKVI Golf (2000) 1.6?
I know I need to remove the caliper, but need to know if I have to invest in some special tool(s)?
Last Edit: Oct 13, 2005 9:59:43 GMT by iRocco
itll be a mk4 if its 2000 mate
Oh yeah - well spotted !
Oct 13, 2005 10:29:52 GMT
when we did the pads on my brother's 2000 Octavia we had to get a 7mm allen key to open the calipers,its an 'oddball' size not in standard hex key kits. A good auto factors should have them
Oct 13, 2005 10:31:17 GMT
Cheers for that - is that the same size used for Ford calipers on MKVI Escorts and the-like?
Oct 13, 2005 10:34:17 GMT
I've used it on Fiat and GM stuff as well as the Skoda, don't know about Fords
Oct 13, 2005 10:48:42 GMT
So I might have to buy one then - !
Oct 13, 2005 10:56:25 GMT
you don't on a mk2 golf. havent a clue what changed in all those years though.
Oct 13, 2005 11:46:23 GMT
Just done friends 1998 Golf Mk4 its normal bolts (no torx, no allen key)!
Oct 13, 2005 11:50:29 GMT
Just done friends 1998 Golf Mk4 its normal bolts (no torx, no allen key)! Excellent news - ta muchly ;D
Oct 13, 2005 14:30:02 GMT
Front brakes should be 7mm alan bolts and rears are 13mm bolts in 15mm inserts, and you'll also need a special tool to wind back the rear calipers if it's the rears your doing (mk4s always sieze at the rear and need plenty of cleaning under the shims.)
Oct 13, 2005 14:36:01 GMT
Front brakes should be 7mm alan bolts and rears are 13mm bolts in 15mm inserts, and you'll also need a special tool to wind back the rear calipers if it's the rears your doing (mk4s always sieze at the rear and need plenty of cleaning under the shims.) Nope - am doing the front. Sounds like I need to get a 7mm allen key Is there enough movement in the caliper to get it off the disc, or do I need to remove the fluid cap so that the caliper pistons can retract back in to the caliper? Cheers Stuyizz.
Oct 13, 2005 15:20:02 GMT
You'll need to squeeze the piston back with some large grips to get the new pads in but unless the brake fluid has been topped up between services it shouldn't leak out. some of the smaller discs will come off without taking the carrier off if you need to change them as well
