just serviced the brakes on the golf...you know usual stuff calipers off and clean up and grease the correct bits etc
ive noticed they had a ring of rust around the edges...i decided to grind it back flush with mr angle grinder , wasnt sure if it would ruin the balance or not
it seems to have improved the brakes a fair bit..i figure maybe that rusty lip was holding the pads away on light applications?
anyone else do this as a matter of routine
yes i know new discs or a skim would be even better , but I'm poor
I used to, but the lip is there for a reason, and with more meat on the discs, you do appreciate the difference in better stopping power once they are bedded in. The Sebring MGB I am expecting to see a big difference in braking to my '73 (It's on braided lines, new fluid, discs and pads, in addition to refurbed calipers). BTW I was poor when I had the Pug . I still put new lower arms and bits onto it (yes it was a bit of a struggle, but it saved me buying tyres like there was no tomorrow.
Last Edit: Jun 6, 2009 20:11:23 GMT by ChasR
what do you mean its there for a reason? they're still good discs with plenty of life in em , I'm not talking a huge lip , its more due to lack of use in my case
It's there because the pads don't cover the edge of the disc, disc wears and leaves the lip, i've ground it off before, right or wrong i don't know, just tides it up before fitting new pads.
"Was today really necessary?"
87 VW GTi ( MOT PASSED 26/04/10)
2003 Honda cb250y Nighthawk
05 Micra Urbis
purplevanman
Way too orangey for crows
It's there because the pads don't cover the edge of the disc, disc wears and leaves the lip, i've ground it off before, right or wrong I don't know, just tides it up before fitting new pads. Me too, same as lip on inside of a drum
