racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
Sept 29, 2005 10:47:27 GMT
Sept 29, 2005 10:51:52 GMT
If they're BMW 4 stud they'll be 100mm, I'd say they'd fit yours but others may use the '100mm is not 4" ' arguement.
It's likely that the seller has measured to the next hole rather than the opposite one...this would give about 3" as a reading.
Sept 29, 2005 11:01:22 GMT
<EDIT> Rmad beat me to it ;D Let me know if you are going to bid on them, because I will if you don't as they are only in Essex I bet he is measuring hole to hole rather than PCD If they were fitted to BMW then they will be 4x100 HTH Dom Ps did you get the other emails ? Would be good to send a summary/thank you to everyone ;D
Last Edit: Sept 29, 2005 11:04:19 GMT by CR500Dom
racer86
Sept 29, 2005 11:03:59 GMT
so chevettes are 4" pcd then. the PCD guide in the features section has them down as 100mm?
racer86
Sept 29, 2005 11:06:04 GMT
<EDIT> Ps did you get the other emails ? Would be good to send a summary/thank you to everyone ;D Yeah thanks mate your my hero! ive replyed to each email saying thanks and discussing my choices I was also going to have a bid on these; again 100mm PCD don't suppose there are any RRers in Hertfordshire who would pick em up for me for beer tokens/cash/women/car parts i have that may be of use to you?
Last Edit: Sept 29, 2005 11:11:28 GMT by racer86
Sept 29, 2005 11:09:21 GMT
so chevettes are 4" pcd then. the PCD guide in the features section has them down as 100mm? 100mm is the Metric-ised version of 4" That's why you get wierd PCDs like 114.3mm and 108mm too. (4.5" and 4 1/4" respectively) It gets a bit wierd with 100mm though, as those clever Europeans were already using 100mm before we went metric and there is a small difference (look on a ruler - it's about 1mm).
racer86
Sept 29, 2005 11:13:35 GMT
well the wheels on it now are 100mm and the holes had to be massaged a little to make them fit so i assume ill get away with it.
Last Edit: Sept 29, 2005 11:14:10 GMT by racer86
SteB
Sept 29, 2005 11:22:04 GMT
Did you buy these? or are they still on't bay ? I really want a set, but they're always silly money or in need of a refurb!
racer86
Sept 29, 2005 11:23:37 GMT
still on the bay, should have kept my mouth shut RR bidding war on the cards ;D it says on the advert 100mm PCD but he had them fitted on a mini? i though minis were 101mm then again if mini wheels would fit that opens up a whole world of wheel options ;D (runs to garage to try mini wheels on shuv) EDIT - just tried a 10" mamba on the back and it goes over the studs bt the studas are not central in the hole. I'm wondering if i could get away with tapered nuts to pull everything straight
Last Edit: Sept 29, 2005 11:30:40 GMT by racer86
Sept 29, 2005 11:30:17 GMT
I was also going to have a bid on these; again 100mm PCD don't suppose there are any RRers in Hertfordshire who would pick em up for me for beer tokens/cash/women/car parts i have that may be of use to you? I could pick 'em up if you like an hide them in my 'wheels shed' for a bit if you like.... do you know which "end" of Hertfordshire they are in?
racer86
Sept 29, 2005 11:34:10 GMT
I could pick 'em up if you like an hide them in my 'wheels shed' for a bit if you like.... do you know which "end" of Hertfordshire they are in? ive just asked and will let you know, thanks mate if i win em that will be mutchly appreciated! (assuming they are close enough too you might be Hertfordshire NZ yet!)
SteB
Sept 29, 2005 11:35:44 GMT
still on the bay, should have kept my mouth shut RR bidding war on the cards ;D it says on the advert 100mm PCD but he had them fitted on a mini? i though minis were 101mm then again if mini wheels would fit that opens up a whole world of wheel options ;D (runs to garage to try mini wheels on shuv) EDIT - just tried a 10" mamba on the back and it goes over the studs bt the studas are not central in the hole. I'm wondering if i could get away with tapered nuts to pull everything straight Minis are definately 4x101.6 (4"), but as you say, all it takes is a bit of massaging! If youve got your heart set on them, i wont enter the bidding fray
racer86
Sept 29, 2005 11:53:21 GMT
don't worry mate, if you have been after some for ages have a bid, id rather an RRer beat me than anyone else! I'm gonna try for the BMW wheels as I'm sure they are the same as what ive got now.
Sept 30, 2005 10:21:11 GMT
Chevettes are definitely 100mm PCD. The underpinnings are Opel, not Vauxhall. Other cars with a 100mm PCD:- 4-bolt BMW 4-bolt water cooled VW/Audi 4-bolt Renault K-series Rovers '90's onward Nissans and believe it or not, sidevalve Morris Minors ( though I reckon 3.5X14" steels probably aren't top of your list.......). They also have metric threads in the engine.
antdat
Sept 30, 2005 10:35:46 GMT
only some sunny's the rest are 114.3mm
Sept 30, 2005 10:36:22 GMT
I'm gonna try for the BMW wheels as I'm sure they are the same as what ive got now. Rob, I`ve just checked the price on these..... Are you still on for them ? I wont bid against you but I don't want to miss them if You can only go to £X amount IYSWIM ;D If you can ket me know that would be good Cheers Dom
racer86
Sept 30, 2005 10:39:13 GMT
Update- i cant bid for either of these sets of wheels now i will have to wait till my student loan drops next week, so BID BID BID
ps still keep your eyes peeled for a set though as of next week!
