I thought I'd put this engine on here before I put it on fleabay.
BMW 525TD M51 engine, complete with all ancillaries including high pressure fuel pump, turbo, alternator, etc.
The engine has done 120k miles and ran sweet as a nut before the gearbox went. Full BMW service history on it, and had just had an oil change about a fortnight ago.
The fuel pumps on these go for over a hundred quid on their own on eBay but I figured it might be more use selling as a whole.
I can supply the ECU too if you want, plus any other bits before the shell gets weighed. The fuel pump is the type that isn't keyed to the electrics so you should be able to plug in and play.
RR might be the wrong place to offer such an engine, but I figured I would do anyhow.
Any questions, PM me, post on the thread or call me on O7967 13689O.
