The Grizzmobile has a column shift, for those who have not noticed. Today I bought an Agate (Stone) head, Tiki-like, kinda crossed with a Buddha head. It has a thin 2mm hole through the centre..... Anyone know how to drill Agate without making it disintegrate into a pile of expensive dust ? Plan "B" would be a thin threaded rod, with ornamental 2mm nut on top, welded at the bottom onto a tapered threaded section to screw onto the gear lever. Any advice on drilling the Agate head to 8-10mm would be greatly appreciated.
Last Edit: May 3, 2009 18:22:08 GMT by grizz
Tricky. If I were to try it, I would say buy a handfull of normal HSS drill bits and drill it out as slowly as you can with medium pressure, changing the drill bit as it goes blunt. No hammer action obviously, and don't press too hard that the bit bites too much materal and tries to rip bigger chunks out. *I'm not an expert, and I have never done it before - just what would try myself.
Tile/glass cutting bit with lots of fluid and gently does it. Other than that, a Dremel with stone grinding bit will work - with some patience.....
Whatcha think Bruce ?
£3.00 bought it.
Quicker than the latex mould route.
Just so happened to notice that my local Aldi had glass drilling bits in with their random tools selection.
Taken from a gem forum.....
After reading all the posts about drilling, I find I have some important things to add. I did an article about this for Lapidary Journal a few years ago.
First, your drilling process will improve a great deal if you add a soluble oil to the water. There is a brand called Tool Cool that works well. This will also save your bit.
Second, when you first start, the bit will cut well. When it begins to slow down, as it will, it is because the diamonds have been worn. If you're using smaller bits in the mm range, sharpen the diamonds and clean the bit by running the tip of the bit over a grinding wheel, preferably aluminum oxide while the bit is under water.
I use an old glass soap dish to hold the piece of stone in which also has the oil and water, about 1/2 and 1/2. You should be able to tell whether you're drilling throught the stone by a swirl of dust that comes out of thie hole. If there is no swirl, try sharpening. Also, once you're finished drilling, the solution can be left to separate and reuse.
If you sharpen and it still doesn't cut, use a fresh bit.
Finally, don't be tempted to turn the piece over and try meeting the holes from the other side. It won't work.
Good luck. the drilling takes much longer than you expect, especially when \you think you ought to be through by now
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
GOOGLE REPLIES:
Drill small holes (under 1") into rock with these simple instructions. The drilling process is the same whether you are working agate, slabs, gemstones, jade, marble, or just about any other type of rock.
1. Start with a diamond drill bit. Diamond bits are the correct type of bits to use for rock work.
2. Diamond bits are meant to be kept wet. The bit doesn’t need to be in a lot of water, just enough to wash away the rock mud and keep the bit wet. The easiest way to accomplish this is to do your drilling in a bin or tub of water. A butter dish works well.
Once you start drilling use a very gentle up/down motion to let fresh water under the bit. If you slam you bit back down on the rock, you will knock off the diamonds, making your bit useless.
Another way of keeping the stone wet is to have a drip system continually dripping water on the point you are drilling. Or, you can have someone with a spray bottle stand next to you and squirt the point of contact with water.
3. Drilling is best done in a drill press. If you tweak the bit, it snaps apart. Holding the bit perfectly perpendicular to the stone is vital.
By following these three steps your bits should give you their maximum drilling capacity.
Just bought 3x diamond drilling bits from a Hong Kong trader on Ebay for £3.50.
That should do the trick.
personally i'd have the stalk turned an re threaded ,you can always build it back out then
yes ,it started badly ,petered off in the middle and the least said about the end the better!!!
DOH ! misread the first bit , 2mm bit tight!!!! sorry
can I just say you've got a nice knob. lol
Nissan Laurel SOLD BMW E34 Diesel SOLD Toyota Soarer 4.0 V8 SOLD Audi A4 1995 TDI SOLD Peugeot 205 1.9 TD SOLD Lexus IS300 SC
