remmoc
Aug 14, 2018 18:34:47 GMT
¥¨†ß˙¥¨¨å it Expansion bottle wasn't the only cause of the leak . As the new bottle is clear it was easier to spot some coolant was escaping somewhere Pressure tested it this evening - leak found , theres a leak between the bottom tank and the rad . No pennies left to fit it either . curse word !!!!
Aug 14, 2018 19:11:42 GMT
At least you found it.
remmoc
Aug 14, 2018 19:45:44 GMT
Yep , not exactly what i wanted to see but no damage done through lack of coolant
remmoc
Aug 15, 2018 16:52:43 GMT
Found the problem re. the rad - it seems the system wasn't pressurising and by changing the expansion bottle and moving the rad cap back to the rad it solved this but created another issue. Now the rad is pressurising it found a weak part that basically wasn't soldered properly from the start So ive re-soldered it as best I can , pressure tested it and it seems to be OK No solder at all under the bottom hose pipe Soldered as best I can Pressure tested again NO LEAKS THIS TIME
Last Edit: Aug 15, 2018 16:55:12 GMT by remmoc
remmoc
Aug 16, 2018 19:02:11 GMT
Done 20 or so miles - so far so good
Aug 16, 2018 19:11:51 GMT
Result nice.
Aug 16, 2018 21:38:09 GMT
Nice one Dave. Glad you got it sorted out. Col.
jpsmit
Here in North America we have a product called Barsleak that you pour in the rad and it will stop small leaks. On the advice of a friend who restores many cars, I put it in when I was restoring the car. Apparantly modern cars get it at the factory. Probably worth doing - belt and braces if nothing else.
remmoc
Aug 20, 2018 18:00:35 GMT
Here in North America we have a product called Barsleak that you pour in the rad and it will stop small leaks. On the advice of a friend who restores many cars, I put it in when I was restoring the car. Apparantly modern cars get it at the factory. Probably worth doing - belt and braces if nothing else. Thanks , we can get this here , rad repair seems to be holding up but il bare this in mind
remmoc
Oct 29, 2018 17:55:17 GMT
So more wiring alterations , Basically ive altered the electric washers so every time these are operated the wipers wipe one full cycle even if the washer switch is released . wipers operate as normal without the washers . As the washers are instant and the wipers have a 1/2 second delay by default ( something to do with the field coil ) theres no chance of the wipers going up the screen dry . Best part is the part required only cost £2
Last Edit: Oct 29, 2018 19:59:10 GMT by remmoc
Oct 29, 2018 19:42:09 GMT
Great work but no video??
remmoc
Oct 29, 2018 19:59:37 GMT
Great work but no video?? Try now , i had it set on private
Last Edit: Oct 29, 2018 20:03:38 GMT by remmoc
Oct 29, 2018 23:14:44 GMT
Great work but no video?? Try now , i had it set on private That's better thank you.
remmoc
Nov 21, 2018 18:46:06 GMT
Hardly an exciting update but ive managed to get a proper factory rear load mat for it , in all my years imping ive never seen another useable one so probably very rare - too rare to use really but there you go , the only difference between this and one you cut yourself is the plain border all around the edge - not exactly mind blowing but there it is
remmoc
Feb 10, 2019 20:37:47 GMT
Last Edit: Feb 10, 2019 20:39:02 GMT by remmoc
remmoc
Feb 16, 2019 11:16:03 GMT
teaboy
Make tea, not war.
Feb 17, 2019 17:25:45 GMT
Tidy job pal.
Feb 23, 2019 20:09:42 GMT
Ahhhhhhhhhhhhhhhh. I was wondering where these bits that were sitting in one of my imps went.... Now I know :-) Carpet looks great. I'll most likely do my one myself too, as I did in my Viva. Much cheaper and can be made to fit perfectly.
Feb 23, 2019 20:16:41 GMT
My God you have big cats in NZ.
I was going to put something else but thought against it. LOL
remmoc
Feb 24, 2019 10:22:05 GMT
Ahhhhhhhhhhhhhhhh. I was wondering where these bits that were sitting in one of my imps went.... They don't go there , they go either end off the parcel shelf between the shelf and the dash top to tidy up the side , its just below the A post , they are glued to thin card The pointed corner facing the ( stunning ) cat is the top corner nearest the door seal so the one on the right is the drivers side.
Last Edit: Feb 24, 2019 10:32:02 GMT by remmoc
