ozzy
its the white ring that sits under the plunger. by taking that out it can move up and down more so you can turn the fuel up more. aw aye, ive got that removed too, release now why its called the 'polo' mod lol I also have the egr completely removed. Are you sure you cant shim the governer springs? the 1.6 VW guys have been doing it for years on their aul yoks. Doing so eliminates the fuel supply being cut off at around 4500rpm. allows her to rev up past 5000rpm. here's info to pump internal modification on a 306, cant see it being too different on a bosch ve pumped corsa. its worth a read if your into diesel tuning. www.pug306.net/forum/showthread.php?t=67216more pump mods are my next job to do once I have re bleed the brakes. so will have a good look at that site thanks
1985 GMC camper family wagon 1989 nissan sunny 1994 fiat cinq my boys car
Fantastic! Daft question, but does it have an intercooler? I couldn't see one in the pics and wondered if it had one as standard or whether you have fitted one or not. Bet it sounds mad with that side-exhaust. That's the nice thing about diesels - no need for back-pressure!
sweet, would tove to hear/see a vid of it running, does it smoke much?
1969 massey ferguson 135- running, with a minor fuel leak 1989 vw polo squareback- scrapped 1988 toyota hilux with rollcage, landrover running gear and soon to be v8 1997 peugeot 306 dturbo -for sale- pm me 2007 toyota hilux invincible - fast and modern!!!
ozzy
Fantastic! Daft question, but does it have an intercooler? I couldn't see one in the pics and wondered if it had one as standard or whether you have fitted one or not. Bet it sounds mad with that side-exhaust. That's the nice thing about diesels - no need for back-pressure! corsa TDs don't come with a intercooler. I had fitted a nice alloy one fitted but had a bit to much fun in the last lot of snow we had it ran a bit higher boost with that fitted and ran a high 14s pass at the pod. I have a cav 2L turbo intercooler in there now but its not as good so have droped the boost down to 1.4bar. so I am on the look out for a better intercooler now but don't want to spend out on a new one.
ozzy
sweet, would tove to hear/see a vid of it running, does it smoke much? I have some vids of it at santa pod when it was not running right ( was testing set ups so got a vids to see how it went ) on the track yes it smokes alot as I up the fuel and boost alot ;D but on the road I drop it down a bit till the smoke stops. I will upload the vids in a bit for you
rtlkyuubi
Low and Slow
a bit chav but looking like a cheap little racer, keep up the good work ;D
Last Edit: May 1, 2009 19:56:17 GMT by rtlkyuubi
ozzy
yep its a bit chav but its the best car to show the chavs how to do it. I pull upto the lights and there is a saxo all chaved up with a 6" pipes, boom boom from there subs and they look over at my satin black corsa and say look at that sh!t and very slow 1.5D and as the lights go green I am gone and leve them it alot of black smoke lol its good fun. they have just been had by one of there own lol
ozzy
not had time to do much to the car as I have not been well. the bakes need bleeding again as air is still getting in. I have got some new copper washes that fit the pipe to the caliper. so will fit them and try again.
is there anyone in the northants area that would like to come a give me a hand ? as bleading brakes is not to easy on your own
don't wanna spoil the fun but get an Eezibleed kit if you're trying singlehanded. good way to spend £16 odd, I've done three clutches now and I never touched hydraulics before that!
that's pretty cool. Love to see summut different!
If the pedal's spongey it's always a good idea to clean out the master cylinder, as after 10 or so years, it gets filled with sludge and backing it up makes everything mushy. I did this and the braking was totally solid.
ozzy
I will have a look at the master cylinder next then. thanks
oh also I now have a easy bleed kit
ozzy
brakes now sorted. but now I have to sell it. not a happy day here as I love ths car.
I hope it goes to a good home.
when I have the cash again I am going to do it again but with a 1.7TD engine. that should be fun.
