Pinto engine, not 205 block, perfect runner, just serviced with new headgasket, timing belt, oil, filter and plugs - £70
rs alloy sump and pickup pipe - £140
rs alloy engine mount brackets but no rubbers - £30
32/36 twinchoke weber on pinto manifold - £60
type 9 5 speed quickshift - £20
pinto lumenition electronic ignition kit inc dizzy and coil - £60
powerflow stainless steel exhaust system twin box, 2" bore centre section with 2 1/4" bore rear section and box, 3" outrolled tip. sounds gorgeous! - £200
any questions pm me.
cheers.
cheers.
