I bought this a few months ago brand new through my Dad
Dad, used ot work at cromwell tools but retired about 7 montsh about ago so i got a good deal
However I've had a change of plans, sodl the car i was going to learn to weld on
Now I'm skint I need to try and claw back some of the costs
Welder RRP is 365.70, they have a promo on new ones form stock at £274.27 INC VAT
I paid £195 for this welder, its been sat in the hallway at home since, still in brand new unopened box
So letting it go for a bargain £150 - collected from either Thatcham or Reading
pm or 07834515382 - withheld numbers are ignored, texts ok
DUAL EMW150 LEOPARD WIREFEED WELDER 230V
Mig Welders
Heavy-duty transformer and turbo fan cooling allows welding at higher power for longer periods. Automatic wire speed control with manual overide. Professional torch with trigger-controlled power and gas prevents undesired arcing and gas wastage. Extra Low current performance - Able to deliver a 30A minimum output for welding very thin material easily. Accepts 0.7kg or 5kg spools for maximum portability and economy. Heavy duty case for durability. Can be used for flux (no gas) and MIG/MAG (gas) welding. Four position, stepped voltage regulator allows process selection to be pre-set. Supplied complete with a smooth action, twin roller feed unit, accessories, two large diameter solid wheels and 2M mains cable. Suitable for automotive, farm, maintenance and contractor use. 2 year warranty. Conforms to TUV-GS, GOST, EMC, LVD and all relevant CE requirements. Insulation class H. Protection degree IP21.
Leopard EMW-150 Dual MIG Welder
Welding capacity: steel wire: 0.6mm - 0.8mm, stainless steel wire: 0.8mm, aluminium wire: 0.8mm - 1.0mm, flux cored welding wire: 0.8mm 1.2. Maximum reel size: 5kg.Input voltage: 230V, 50/60Hz.Fuse rating: 16A.Phase: 1.Power consumption: 3.7KW max. (1.4KW 60%).Output current range: 30A - 145A (DC).Open circuit voltage: 31V.Dimensions: (L x W x H) 680 x 285x 410mm.Contents: LeopardTM EMW-150 power supply. 1.8M cable, 10mm2. Earth clamp, 150A. 2M MIG torch, 160A. Flux cored wire coil 0.9mm x 0.2kg. Hand held face shield with 51mm x 107mm glass. Scratch brush and slag remover. Instruction manual.
pictures and wording taken from cromwell tools website listing
Mig Welders
