May 16, 2009 21:02:37 GMT
How about some sort of multi barrel set up? Say have 6, joined in a sort of minigun looking arrangement, each loaded with a bit of tatey. Then you simpley recharge the air cylinder between shots and click the next barrel into place Either that or another idea that I cannot really explain without the aid of graphics, which I might do later to explain my point.
May 16, 2009 21:07:13 GMT
How about some sort of multi barrel set up? Say have 6, joined in a sort of minigun looking arrangement, each loaded with a bit of tatey. Then you simpley recharge the air cylinder between shots and click the next barrel into place Either that or another idea that I cannot really explain without the aid of graphics, which I might do later to explain my point. Trouble is, it's not the barrels or the loading that takes the time, it's recharging the air pressure, possibly splitting the chamberinto sections and charging them all, firing one at a time.
"Chasin' the gash, with a four-out-the-dash"
May 17, 2009 14:24:36 GMT
I got brave and got my mate to shoot me in the ass ;D
Take 1:
Take 2:
We couldn't look more gay if we tried ;D
Tim
May 17, 2009 18:02:52 GMT
You maniac, that looks great fun :-)
May 17, 2009 18:06:03 GMT
haha, mental!
I need one now!
skinnylew
Club RR Member Number: 11
May 17, 2009 18:46:39 GMT
hahahaha thats crazy
May 18, 2009 17:14:22 GMT
You could of worn pink.... Highly amusing, do you come with your own personal safety warning sticker??! Oh and we need evidence of the bruise.. I'm assuming it left one?!
Daily: Spazda Mx5
'A52's Fastest steak eater 2010'
May 18, 2009 17:26:26 GMT
laughing my ass off!!
May 19, 2009 14:46:12 GMT
Oh and we need evidence of the bruise.. I'm assuming it left one?! I seem to have gotten away with only a small bruise. Must be because it hit the fleshy part ;D
May 20, 2009 11:57:06 GMT
I think that's the best use for a Frenchman that I have ever seen *n
May 20, 2009 13:36:59 GMT
Take a look about, maybe there is a 12volt compressor that really can deliver out there, then you carry that in the 2CV and reload in transit. I did wonder about hooking up my compressor to an inverter and leaving it running, then after each shot is fired refill the spudgun from that, I'm not sure what kind of pressure a 12v tyre inflator type cheapy thing will get to, but that'd be a better option if it'll reach 100psi or so, although it'll take a lot longer to refill. Something makes me want to get one of those cheapy compressors- the twin-plunger types are quite good, will manage about 120psi, but instead rip out the electric motor and fit a weedeater petrol strimmer engine on the back of the pump and drive it with that... no wires, just start it up and off you go... But that'd be a whole other project in itself lol ;D --Phil
Last Edit: May 20, 2009 13:39:13 GMT by PhilA
May 20, 2009 14:39:28 GMT
Hey, long time no see Penski! This is a sneak preview of the Mk2 jet scooter, twin folded valveless pulsejets
Last Edit: Jan 8, 2010 15:06:01 GMT by Deleted
May 20, 2009 19:09:36 GMT
Oooooo nice.. wanna make me an exhaust! lol (please add video involving lots of noise and fire soon... thankyou muchly!)
Daily: Spazda Mx5
May 20, 2009 22:14:54 GMT
Thats going to be nice and hot around your legs Jonny!
Last one we built colapsed from the heat, got half of the second one in the shed.
Dropfiles has gone and gone bust so I've lost all my pictures. I'll try and get them replaced asap. I've been toying with some bits for the Mk2 jet scooter, one which will have more thrust, proper throttle control, some brakes and will be realistically rideable. I've built some bits but no way near all of it yet so this is more of a build diary. One big jet is a bit unmanageable in terms of physical size, logistics of making it and materials cost/availability. Two smaller jets can be made using off-the-shelf materials and provide the same results, so I've opted for two jets similar to the one on the old scooter, running in a valveless configuration for longevity and turned back on themselves for maximum use of the thrust. Similar to this one in fact, but a lot smaller: Check out the dude on the left The jets are U shaped which might seem a little strange but I'll explain how it works. In a valveless pulsejet you end up with a portion of the exhaust coming out the intake during the combustion phase, about 40% in total and the other 60% goes out the exhaust end. If the intake is facing forwards then it works against the rearward thrust, but if you turn the intake backwards it works with it. You can't suck yourself along, so during the intake phase the inlet will not take thrust away and we won't be working at high enough speeds that ram-air will affect the intake. Science lesson over, lets get on with the build. Mine are going to be straight sided tube and I can get two U bends in 2" exhaust tube, shown here cut down so when complete the intake tip will be level with the exhaust: Extend to the desired exhaust length: The intake is a single straight section of tube. Previously I've used multiple tubes to get the desired area but this time I opted to cut a slice out the middle of a larger diameter tube and re-roll it to the desired diameter: Onto the combustion chamber. Some endcaps for the intake tubes: The intakes weld into these and they are simply drilled with a cheapo Screwfix holesaw and the outside diameter cut and dressed with the grinder: Welded into place: The combustion chambers themselves are lengths of 100mm diameter steel tube carefully cut to size with the grinder: I got a nice square cut at each end to work from where the length was cut at Metal Supermarkets, but ultimately it's going to distort quite a lot when it gets red hot so there's no point being too fussy about it being perfect. Rough layout is this, before I make up come cones: And to make the cones you can see a card template on the right which I used to make the shape before transferring to sheet steel: Forming the cone is quite easy with a bit of practice, just working the steel by hand slowly, checking, work it a bit more and so on. No complicated tools needed here And that's where I'm up to. I've got a little vehicle from Freecycle that may donate some parts, namely the wheels, forks, headstock, brakes etc: The engine is scrap but all the bits I need are in fine working condition
Turned out alot better than our First jet, good work!
can't wait to see it running
how is ignition achieved then Jonny? or are they self perpetuating after they are lit?
(seem to remeber seeing one being lit with a leaf blower on scrapheap challenge once)
DutyFreeSaviour
oooh - likin the idea of one of these
I was looking at Puch Maxi videos on Youtube. Found this one. At 2 30 theres a Maxi with 2 large pulse jets on the sides.
how is ignition achieved then Jonny? or are they self perpetuating after they are lit? (seem to remeber seeing one being lit with a leaf blower on scrapheap challenge once) To get it started it need a spark and some air shot in the front. Once it's running it's self perpetuating. I use a little 555 circuit and a car coil to fire the sparks and a manual airbed pump shoots enough air in to get it started. Used to use a leaf blower but it doesn't need that much.
