1st of all fuel ( a BIG part of the RV8!)
any idea what the ideal fuel pressure should be - i have a fuel regulator / filter where you can 'dial in' the pressure.
secondly - oil pressure - I have 2 outlets on the oil pump, both electrical, one is a simple screw in switch (looks like a water temp sender) and the other has a 'bulb' on it - which can I connect to my SD1 dash gauges to read the pressure ?
any help, as always, appreciated !!!!!!!!!!!! ;D ;D ;D
