Sept 16, 2005 17:40:13 GMT
Is there an oil thickener/gasket sealer stuff?
I seem to remember that it existed but no can't find it!!!
have various leaks on the Mr2 and want to try and plug them from within...
BigWig
Sept 16, 2005 18:17:29 GMT
Gaskets are peanuts, don't be tight! ;D
Sept 16, 2005 18:28:04 GMT
You can get a few different types of additives that do help. Have a look in your local motor factors. But most are pretty limited as to what they can do so I wouldnt expect a miracle cure. I can imagine it being a daunting task changing gaskets on a midship engine, but it is really your best option
Sept 16, 2005 19:29:40 GMT
Is there an oil thickener/gasket sealer stuff? I seem to remember that it existed but no can't find it!!! have various leaks on the Mr2 and want to try and plug them from within... Lots of little oilways in there as well Do you want to plug them Too Ghanging a couple of gaskets now is a lot easier than fixing the damage from a Rod letting go at 7000rpm though lack of oil
Sept 16, 2005 22:18:00 GMT
Davenger
It's only metal
Club RR Member Number: 140
OIl thickener? Davenger
@dminifreak
Club Retro Rides Member 140
Sept 17, 2005 0:14:45 GMT
Sawdust Sorry, couldn't resist it, seen it done/done it when I used to work for a dodgy car sales place many moons ago, closed down now (thank god)
Sept 17, 2005 8:59:33 GMT
Gaskets are peanuts, don't be tight! ;D But I don't have anywhere to work on a car at all and need a temp fix until i can find somewhere...
