Apr 16, 2009 13:10:50 GMT
I've got a set of wheels that have been polished (well, a machined fine diamond turned finish) then lacquered, but there are a few water marks under the laquer. Seeing as the surface is good, I want to minimise the work I have to do by using a chemical stripper to take off the laquer before polishing them, this way I can just go ahead and polish the diamond turning out (Not a lot of work) rather than having to bring them up to a 1500grit from whatever abrasive I used to take the paint off.
Will nitromorse react with the aluminium and make it go dull? I know a lot of acids can, but I'm unsure how Nitromors works. Cheers
Apr 16, 2009 14:03:42 GMT
Ive done this before but a while ago.
I seem to remember it was fine. Just used some fine wet and dry after to get rid of teh turning patterns then polished.
Apr 16, 2009 14:06:00 GMT
Cool, thats good enough for me. I'll give it a go. Cheers!
Don't suppose anyone knows where I can get nitromors cheap?
Apr 16, 2009 14:07:40 GMT
its fine done a set of ats classics got the laquer of a treat
Apr 16, 2009 14:09:02 GMT
its fine done a set of ats classics got the laquer of a treat Cheers, any tips?
Apr 16, 2009 14:32:39 GMT
I've put it on polished ally and its fine, just put it on as per instructions on the tin - dab it on and wash it off after a while. I also used it on a helmet. Nitromors and plastics don't appear to mix too well ![:-/](//storage.proboards.com/forum/images/smiley/undecided.png)
dubzi
What they said^
Just stripped the lacquer of an ATS cup and it didn't affect the alloy at all.
I didn't know that before I started! Just took a chance and it turned out OK for once!
Happiness ain't at the end of the road. Happiness is the road.
kee
i have on my alloys, as said bit of wet n dry then some autosol and the rims where a sparkly shiny thing again ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Ive used wire wool to rub of the paint stripped paint goo from an alloy mountain bike frame. was nice and shinny then
Apr 17, 2009 11:25:00 GMT
Well I went to get some nitromors and realised I was flat broke. not a penny to my name, so came home with my tail between my legs.
Found a tin of the spray on stuff under the sink, says "not for removing paint from car body panels" but I thought sod it and I've given it a go.
I suppose we'll find out the damage in about 20 minutes!
