paul4be
'86 Capri Laser, Frontera 4x4
Apr 15, 2009 21:40:26 GMT
Want to spary a complete underside with waxoil or similar, don't have a compressor to use. Thought about thinning slightly with white spirit, making sure it's nice and warm then just using a pump up garden sray (the 1L ones that pressurise and just have a spray, not a long hose and nozzle).
Any other ideas as it will need to be sprayed to get into everywhere. Have once tried the proper sray kit, but didn't find it very good, especially for the money.
purplevanman
Way too orangey for crows
Apr 15, 2009 21:43:20 GMT
I would find a compressor, you can pick up a new one for less than a ton or s/h a lot less. Just one of them little buzzy ones would do.
Apr 15, 2009 21:47:20 GMT
A few years ago I bought a waxoil spraying kit which was basically the garden sprayer and it was less than useless.
I have a compressor now and it is FAR easier.
Buy a cheap compressor of borrow/hire one. The time it will save will pay for itself.
Apr 15, 2009 21:55:06 GMT
Whichever way you end up spraying, I find sticking the tin in a bucket of boiling water for 10-15 mins before using, turns the waxoyl very runny, making it excellent for getting into those hard to get at places.
Apr 15, 2009 22:04:03 GMT
I tried spraying it with and airline and didn't have any luck, I use the waxoil pump up tin thing which works OKish but you have to get it nice and warm first as already said with a bucket of boiling water, you have to get the hose and trigger in as well or it just sets again and won't come out.
mym
Apr 15, 2009 22:37:05 GMT
lae
You can thin the first coat of waxoyl with used engine oil, thins it down loads and it seeps into gaps and cracks really easily. Then you can go back to it and put on undiluted waxoyl. Makes an already messy job even more messy though and drips on your drive.
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
Apr 16, 2009 13:29:11 GMT
i have the waxoyl's own sprayer gun and found it really easy to use, i had no issues! But defo need to make sure it's warm first! Slightly cool waxoyl makes for lots of time unblocking it!
bortaf
Apr 16, 2009 13:59:47 GMT
Ive used the standard spray tin 10 or 15 times and it's a pain it the waxoil aint hot, last time i used a fence spraying leccy job but again if it was thick it blocks up, i used diesel to thin it and it was fine.
R.I.P photobucket
purplevanman
Apr 16, 2009 18:04:13 GMT
Forgot to say in my first post, i wouldnt use waxoil anyway dinitrol or just old oil get into the seams much better. Not seen Myms suggested Bilt Hamber stuff but they are generally good.
Apr 17, 2009 22:23:35 GMT
a good tip with the waxoyl pump is to have a friend do the pumping while you negotiate all the spraying. oooh errrr!
@ CRX_IN_SCOTLAND
