hi all
just a quick question regarding the dash lights in a citroen ax "splash" circa 1988 .
no different from standard apart from hubcaps!
anywhos. the girlfriend has brought it for her first car and the only prople she has with it is the speedo does not light up when the lights are on, i was just wondering if anyone knows what the proplem could be
dodgy connection?
wibblepoo dash?
blown bulb/fuse?
as I'm rubbish with electrical stuff.... well not up on it should i say!
also how would i go about getting the dash setup out and does anyone know what sort of bulbs i need to replace some of the other bulbs, like indicator, handbrake light?
cheers for you help
robin
dodgy connection?
wibblepoo dash?
blown bulb/fuse?
cheers for you help
robin
