Hopefully I'll win one on the bay this afternoon. If it's good, behind the front bumper. If it's bad, on the front bumper That said, are they relatively easy to plumb in? *n
well if you aleady have somewhere to take the pipes off, its easy if you don't its gona be fun
racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
ive looked into this on my shuv and i don't think you can fit one to 1256, the only way i can see is a spin on filter conversion with a sandwitch plate.....but does anyone make a spin on conversion that fits?....Probably but i have'nt found them yet! let me know if you turn anything up!
well I'm assuming your shuvit uses the same filter as a nova/astra/cav etc if it does get the oil cooler plate pipes ect off a cav gsi/astra gte remove the normal screwdown thread with a screw extractor and use the one supplied - cheap instant oil cooler
Aaron
Sept 6, 2005 10:23:52 GMT
When I was fitting the 4A-GE engine in my Toyota, I wanted it as low as possible, but the oil filter was in the way of the engine mount. Think Automotive were able to do me a Mocal take-off plate, remote filter housing and all the fittings and pipework I needed to install an oil cooler at the same time.
Aaron.
1975 Toyota 1000 with 4A-GE (tweaked a bit)
1992 Nissan GTi-R (now sold after 17 years)
2001 Subaru Impreza WRX (remapped)
Sept 6, 2005 10:29:39 GMT
I'm pretty sure that someone makes a sandwich plate that's available in various diameters and threads, failing that, try a remote filter kit for an engine with the same thread as yours, and plumb it in that way. The thread should be marked near the seal, try checking a filter in Halfords if you're not taking yours off anyway. (See, Halfords do have their uses!) If it's any help, the Pinto, Fiat Twin-cam, Renault 5 and Reliant Robin(!) all use a 3/4" UNF thread. For a sandwich plate, try Mocal, Merlin Motorsport or Europa.
Sept 6, 2005 12:27:03 GMT
Well I won it - £16.51.
I'll have a good hard look at the options once it turns up.
*n
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Sept 6, 2005 13:49:38 GMT
Go to Think Automotive. They are the boys for oil cooler. They will sell you a sandwich plate to fit your engine along with any pipes etc you might need. Adapter for the ZS was £16 plus postage.
This space available to rent. Reach literally dozens of people. Cheap rates!
Sept 6, 2005 14:52:15 GMT
Sandwich plate is the way to go. But make sure you get an oil stat as well otherewise you will overcool your oil which is not a good thing with most oils.
Sept 6, 2005 15:41:17 GMT
racer86
Sept 6, 2005 17:54:54 GMT
mmmmmmm come to Robbie! When i had an oil cooler on my Mini without a thermostat i made a perspex cover for it in winter, it was a winner!
