oli
blah
Aug 31, 2005 21:10:30 GMT
Just wondering if anyone knew of any companies (UK) that did custom coilover setups.
as finding stuff for rarer older cars like the starly is pretty difficult.
any places to look??
Aug 31, 2005 21:20:49 GMT
avo or spax do that sort of thing don't they? sorry got no links.
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Aug 31, 2005 21:27:40 GMT
I'm sure you can buy tubes that fit over your struts converting them to coilover. No idea if this good or bad though? Could be the new spring clamps.
This space available to rent. Reach literally dozens of people. Cheap rates!
Aug 31, 2005 21:35:13 GMT
Aug 31, 2005 22:07:41 GMT
All of the above plus Gaz and Leda either in kit form or they will convert them for you
I called Dampertech and the guy was really helpful,... wasn't cheap though 600-ish quid,.. all in. That converts from struts at the front to coil overs,.. and uprates the dampers and springs at the rear.. Oh and it was all fullt adjustable
oli
blah
I called Dampertech and the guy was really helpful,... wasn't cheap though 600-ish quid,.. all in. That converts from struts at the front to coil overs,.. and uprates the dampers and springs at the rear.. Oh and it was all fullt adjustable Was this a general car quote or a specific model? Fully adjustable sounds 'hella sweet yo!'
slater
Club RR Member Number: 78
custom coilovers?slater
@slater
Club Retro Rides Member 78
Swap to struts from a more common car if you cannot find upgrades for the ones you have got. (everything is avalible for escort mk2)
mercmad
Sept 4, 2005 11:52:10 GMT
From the late 70's i made my own 'after a fashion' ,you could always find good ones on the front of Hillman imps.Or triumph hearalds,of course they weren't adjustable like the always mega expensive Koni's et al .On my roadster i have XJ Jag rear coil over units.The springs were way to hard so I got some springs from the front odf a Suzuki ST90V carry van,exactly the right fit but a lot softer and gives it a ride that is quite good,not hard but not soft either.
