V8 engine block, Y block from a Ford T'bird.
Bare block, been prepped so that it has a totally flat top, and totally flat bottom.
all sharp bits and pieces and extremeties stripped.
Its currently mostly in black, with silver faces on the head areas, but the paint job is rubbish, and some wasnt painted so has surface rust.
I was going to blow the whole lot over in silver hammerite and plant flowers out the bore, but its not allowed in the garden. To be fair its a bit out of place.
£25.
If you are local-ish to me I might be able to deliver, but I'm based in Sandhurst Berkshire, GU47 0UH.
£25.
