I have sitting in my garage an SD1 3.5 litre rover V8 engine in pieces. The plan was to fit it to a Triumph Dolomite I have but I never got round to it and the more time that passes the less likely it's going to happen.
All the bits are there, twin SU carbs, starter motor, sump, heads, rocker covers, etc, etc, including a few boxxes of 16 brand new rockers. I took a piston and bearing cap off the engine to check for wear and to see what sizes they were, no worrying wear and everythings standard size.
I also have the LT77 gear box for this engine although I'm not to sure if the selector is there, I will check it out and report back.
One more thing which may be of interest, I have a Dolomite subframe in good condition with brackets welded on to take the Rover V8 engine.
I'm open to offers on all of it or splitting it
All bit's in South Wales just outside Swansea
Thanks, Adam
Thanks, Adam
