I used to have one of these , english version is the renault 11 , mine was a 1.4 turbo as found in the 5gtt , the engine block you have is the same as the volvo 480 turbo 1.7 , would be a very easy and cheap conversion if you can find one over there,. I'd love to but they never sold them here. It's nearly-but-not-quite the same! It's the 1.7 turbo head but the block is a bit different (taller) with a longer throw crank. They only made about 2000, of which probably 1000 have already vanished due to corrosion or failed engines. People didn't like to change the cambelts because it was expensive and drove them until they went BANG and just left the vehicles at the side of the road where they stood to be collected, impounded and then crushed. Parts are therefore getting somewhat thin on the ground. --Phil
great work as always Phil if you get stuck with parts etc ,don't hesitate to give me a shout mate I always keep spares of everything ,lol Got any working indicator switches? Mine died lol The ratchet mechanism inside no longer puts the main beam on when you pull the stalk with the dip lights on. It flashes them though but from what I can see that's a different ratchet. --Phil
great work... a lot of dedication, and understanding from SWMBO! I'm still worried once I get it running one day it'll just vanish, and there'll be about thirty dollars sitting on the kitchen table when I come home with a small note "here's the change from your car" heh --Phil
great work as always Phil if you get stuck with parts etc ,don't hesitate to give me a shout mate I always keep spares of everything ,lol Got any working indicator switches? Mine died lol The ratchet mechanism inside no longer puts the main beam on when you pull the stalk with the dip lights on. It flashes them though but from what I can see that's a different ratchet. --Phil common problem on renaults of that era mate . i remember having a spare switch somewhere ,i will see if i can find it in my aladdin`s cave of parts ,lol
Aug 30, 2010 17:28:23 GMT
common problem on renaults of that era mate . I remember having a spare switch somewhere ,i will see if I can find it in my aladdin`s cave of parts ,lol So I read on google. Apparently turning the lights off with the main beam engaged breaks the mechanism off inside Good design, especially considering it's not a forward-to-latch high beam switch. I think they tried to cram too many functions inside it --Phil
Aug 30, 2010 23:19:27 GMT
Good job that you got it running!
Your 2 liter block has unique bore stroke combination which was never in the EU. We only got a 2-liter block in 1993 and that one features a different bore and stroke.
Perhaps you could find parts from Latin America. Renault had/has a engine factory in Brazil.
Click picture for more
After a short hiatus, where I took one of the front hubs off to have the new bearing pressed in after the old one removed. The guy wasn't able to do it this week, so I did something I knew I could fix tonight. Not that impressive but crappy, milky yellowed lenses really detract from the front of the vehicle. I knew that they'd never look great, but gotta try and make a bit of an impact: Left one attacked with plastic polish and a lot of elbow grease. They glow okay: One item down, a bunch more to go. --Phil
Sept 7, 2010 23:39:22 GMT
Had the replacement wheel bearing pressed in today. Looking a lot better but the guy said he was having to press the old piece so hard it nearly pushed his tool apart. It took a 20 ton press and a bearing puller used in conjunction with each other to get the old one out it was so malformed and rusty. He said it looked like the original factory one. I said I didn't doubt that. Twice what he quoted for the job later ($31 lol) and I have a shiny new SNR bearing in there. He said he'd take on the other side if required, so he's still undeterred! One more task off the list. --Phil
marksparks999
I aim to live forever, or die trying!
Sept 8, 2010 16:50:04 GMT
i have an oldschool renault specialist about 15 miles from me in Exmouth... he has all sorts of really nice cars in his yard and on his drive... if you get stuck for any parts, let me know i will go and speak tohim see if he knows where to find them!
Retroless at the moment... but on the hunt for something old!
Sept 8, 2010 22:42:11 GMT
Thanks!
Had everything together so shot a few videos today.
Headlights and hazards on. No seperate sidelights, rather like lighting laws in the UK up until the early 60's. Needs a new headlamp bowl and a pair of new headlamps (sealed beam, them) to make it fit to drive at night.
Starts up now, adjusts itself (badly)- at no point until I rev it up did I touch the gas pedal, it did all that itself- and responds well to throttle. Needs a couple new coolant hoses for the radiator and heater where one's perished and the other needs an elbow to fit the new heater spigot.
Not much progress, but starting it up occasionally makes me smile and going vroom vroom makes me feel like a big kid in a bumpercar lol
--Phil
Last Edit: Sept 9, 2010 1:34:58 GMT by PhilA
Sept 10, 2010 0:17:29 GMT
Some more kinda random detail shots of the car, as it stands today Front of the car. Front foglight, SEV Marchal, manufactured by Valeo. Back of the car. Got a plastic plate on it from a local dealership. Fixed the numberplate lights. they work well now. Looking into the boot. Detail of inside boot. Driver's side detail. Straight, but missing some trim. Slight crease at back edge of door where someone's tried to break into it in the past. Passenger side. More of the same. Knocked out the dent that was behind the door. Wheelarch detail. Nice and clean apart from spiderwebs and spiderpoop. Engine. Detail of engine. More engine. Build and emissions labels. Dashboard. Original mileage. Vacuum-fluorescent digital clock. Retro Standard turn/lights/horn stalk and optional cruise control stalk. Manual air-con heater controls. (As opposed to the electronic one they had with buttons). Sun visor on passenger side, with lights. Quite a lot of stuff from a middle-of-the-road spec vehicle. --Phil
Sept 13, 2010 2:50:22 GMT
Still getting over the cold I've had the past week, but today saw the purchase of $2.83 of CVS Pharmacy Denture Cleaning Tablets. I've not yet lost my teeth, so purpose for these is the car. A couple people noted good devices to clean up the heater innards of an engine, and suggested denture tablets. I popped the bleed valve off the top of the radiator to check it hadn't airlocked, it widdled clean water everywhere (good sign). Evicted a lizard and a frog from the engine bay, and got in the car. Forgot that I had removed the dash to change a lightbulb. Put the dash back in, broke two pegs off the plastic by accident, spent time fixing that, it got dark, it was too hot, ran the car for a while and discovered that the ICM has jammed up again. Time to lift that off, because bizarrely the engine manages to regulate itself down to a low idle without being able to adjust the throttle stop position. By the smell of the exhaust and roughness of idle it feels like it tweaks the fuel and timing to bring the engine speed down. That must be why the innards of the engine were sooty. So, ICM comes off again and gets taken apart again. Driveshafts have been put on hold as my overtime last paycheck didn't cover everything and SWMBO said no --Phil
Sept 13, 2010 7:47:01 GMT
just read the whole Thread... wouldnt it be muuuuch easyer to insert a Megane 2.016v F7R Engine in it? or the 1.8 16v F7P from Clio 16s/R16 16S?
Sept 13, 2010 10:29:56 GMT
just read the whole Thread... wouldnt it be muuuuch easyer to insert a Megane 2.016v F7R Engine in it? or the 1.8 16v F7P from Clio 16s/R16 16S? Depends on where you live !! ;D
Sept 13, 2010 14:49:44 GMT
just read the whole Thread... wouldnt it be muuuuch easyer to insert a Megane 2.016v F7R Engine in it? or the 1.8 16v F7P from Clio 16s/R16 16S? Considering neither the Megane nor the Clio were sold here, no. Hence why I'm rebuilding the current engine. This was the only instance of the Fxx series engine sold in north America, and it differs from any other with a different crank and bore. (93mm stroke, 82mm bore). All the other series engines were either the 1.4 Cleon or the 2.1 or 2.2 variants which are architecturally different and just as scarce. There were only produced about 2000 of these engines so finding parts is hard. A lot of people who race/d them fitted 2.0 or 2.3 Pinto or Lima engines from the Mustang, claiming greater reliability and spares availability. I'd love to be able to put a 1.7 turbo lump out of a Volvo but again, another variant of an engine that was never sold here. I'd have to import it in pieces too because a) entire engine would have to meet EPA regulations for emissions (the Volvo units do not) and b) it'd be expensive to import by ship. Either way, it runs. --Phil
Sept 14, 2010 0:44:04 GMT
I was a bit stuck for things to do, so this afternoon after having scoured the shops for small 1.2W capless peabulbs that had been dipped in resin to shine a colour and coming up with nowt I stopped by Radio Shack, had a rummage about in their LED drawer and came up trumps with a wide angle (well, wide in terms of LED's, 40 degree) 800mCd red LED. Think brightness of a mini Maglite. They sell the 5W ones like you put in sidelights but not the real little ones. Did a quick bit of calculation and purchased a set of 330 Ohm resistors to put two together to make the requisite 650-odd Ohm to reduce the forward voltage and current across the LED so it can be plugged directly into the car's 12V system. Max forward voltage on the thing was 2.4V! Found an old lampholder and came up with this creation- regular bulb in a socket on the left and LED on the right. I decided upon this because every time I switch on the car I am greeted by this: The gels in front of the lamps have cracked and crazed with age, heat and sunshine. Fitted the new contraption, took it out and put it in the right way round (yay diodes) and got this, which my camera tried to mangle the colours as best it could. Believe it or not the oil pressure light is now a nice solid crimson-red. I think next up will be the turn-signal telltales, which should do really well with bright green LED's. --Phil
Sept 15, 2010 5:40:20 GMT
Continued with the LED theme tonight, but the green ones I bought are possibly not up to the task so I started with the blue one for the high beam indicator lamp. Here's a bit of a howto, to fit LED's into the tiny little 1.2W capless bulbholders for warning lights. Firstoff, this only easily works with the older style ones where the bulb comes out of the holder. The newer ones tend to have the bulbs fixed into the plastic. Grab an assemblage of parts. I went to Radio Shack, but stuff from Maplin, RS etc. works the same. I bought LED's in the range of about 1Cd (one candlepower, oft referred on the box as 1000mcd), with a forward voltage between 2 and 3 volts depending on the colour of the LED. To run the LED's on a 12V car system you need to drop the voltage down, so I worked it out- 650 Ohm for the 2V ones and 450 Ohms for the 3V ones. I divided each by two so I'd have a resistor on each leg, added the values together and makes the legs the same length. Snip, snip, solder, solder. Two 220 Ohm resistors on a 3V blue LED. I got the one with the widest "viewing angle", ie the bright spot of light it makes is really big close to on this one. It's a 330mcd one, not one of the insanely bright (3000mcd) ones. Now it'll happily run off a 9V battery. Without the resistors it'd be very bright for about a second or so then burn up. Grab the connectors with pliers. Pull the little connector pieces out carefully. Position the legs inside the original spring pieces of the bulbholder, with the resistor in the cup of the spring where the bulb would push in. Keeping it short here means that the LED won't stick up much further than the original glass bulb. I could probably have made it shorter by clamping the resistor in the spring section. Carefully solder the pieces in, taking care not to overheat the resistor. About 5-7 seconds of hot iron is about as much as they can take. Soldered in. Repeat for the other leg. Tidy up with a bit of insulating tape and push the connectors back into their grooves. This assembly will tolerate being plugged in backwards briefly, and will outlast any filament bulb you can fit, with the added advantage the colours tend to be a lot more rich than the printed gels. Downside is some LED's need their faces ground down slightly on a file else you get a bright spot in the middle of the warning lamp and nothing else. I ran out of time tonight before being able to take in-dash shots, but basically instead of being a sickly greenish-turquoise, my high beam warning light is now a very certain blue. --Phil
Sept 15, 2010 22:57:14 GMT
Before and after shots, these ones show a good difference: Before, standard lightbulb: After, blue LED: The LED is brighter, but I tried it last night when it was dark and it's not in-your-face bright, but you do know the main beam is on. It's also bright enough to be seen during the daytime. Useful for here when it's raining because lights have to be on by law here in the rain. --Phil
jr19
Sept 16, 2010 8:04:50 GMT
swmbo says no to the big stuff (driveshafts) but you get your fix with the small stuff, quality. A real craftsman!
