I am 99% sure you didn't get these intake on your side of the pond. I originally picked it up at the wreckers here to try to adapt to one of several small bore 4 cyl, and it has some nice engineering, and a nice fabricated look. It is adpatable as it has 180 deg runners of very ductile thin wall ally piping. They start off at 6cm spacing and curve so as to separate- at the 90 deg point they are 8cm and at the head flange they are ~97mm spacing. Pipes are not tapered. They are 35mm ID, and the plenum, which is not tapered either, is about 51mm ID. The entry of the runners at the plenum is very nicely finished inside vis-a-vis airflow.
Good for an IMP, a K1100-headed A series, maybe a small Fiat, or a bike engine car.
You could cut the flange off and or weld to it. If you cut the flange off you could respace the pipes. Care would be required to reweld- I do not know the metal used in the piping, but it appears to have been soldered .
After all this, I only am asking that the "buyer" cover the mailing from Canada. I'm not asking for anything, just hate to throw it out.
Mailing could breach the $30 mark with some bad luck, tho.
I've also got a crusty old Zenith Stromberg off a Volvo of the early 80's variety. I did not intend to use them together, but after sitting on the same shelf for 5 years, wondered about it. Can't imagine it's worth shipping unless you want it with the manifold.
