Rob
You know, for kids!
Aug 20, 2005 19:35:04 GMT
i have just bought (and promptly fitted) a 1.75in SU (HIF44) - it has all the usual take offs - servo / oil breather etc... but. there appears to be 2 fuel inlets ?? one highr than the other and on the same side... I'm thinking that one may be a fuel return as this carb was used on the metro turbo setup which had a return . . . any help, as always, appreciated. ;D
Rob
You know, for kids!
Aug 20, 2005 19:36:42 GMT
heres the beast... you can see one fuel pipe and the oil breather on the right . . .
Aug 20, 2005 19:54:12 GMT
Mmm I'm not sure if this helps you Is it number 8 your talking about?
slater
Club RR Member Number: 78
Aug 20, 2005 20:27:42 GMT
Block it up
Rob
You know, for kids!
Aug 20, 2005 22:14:01 GMT
Block it up was that a serious answer ? sorry to be dumb. heres the actual carb its the one that the pipe is on . . . i guess it looks like the last person just vented it to the floor ! ?
Last Edit: Aug 20, 2005 22:18:31 GMT by Rob
Aug 20, 2005 22:38:44 GMT
I reckon its a vent thing for if the needle sticks and the float chamber overfills. I'd vent it to the floor also. only there for 'emergencies'.
Rob
You know, for kids!
ill give that a go... sounds reasonable... cheers ministrone for that image and slater and plums !! lets see what happens . . . hopefully have video of the pick up's engine running today too if i get time . . .
slater
It was semi serious. The one the pipe is on is the breather from the float chamber and needs to be vented to the atmosphere The one below it is the fuel inlet The one on the right is to do with the crank breather arrangement and should be blocked up.
Rob
You know, for kids!
cheers slater . . .
