Feb 28, 2009 10:36:05 GMT
Not old, retro or classic but here I have a 1995 Subaru Impreza WRX V-Limited. It's got crash damage to the drivers side wing, bumper and head light and (one of) the head gasket has gone. It's V-Limited 924/1000, 70,000KM on the clock, Has a few non standard things like; Blitz dump valve oil pressure/fuel pressure/boost gauge pod WRX alloys with near new tyres Cusco height/rate/camber adjustable suspension boot spoiler with stop light. etc etc All parts available, do get in touch, car is in Neath in South Wales. Thanks, Adam
dbug
Feb 28, 2009 13:36:46 GMT
hi, what size are the wheels and how much you wanting for them.
mitch
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Is the dump valve twin piston? If so would be interested. On another note i'll have the guage pod.
Also depending what turbo it's running i'll nab that as well.
hi mate. sad to see it being broken how much are you looking for the wheels and cusco suspension?? Dave
Hi guys, Is a pity to break it but I don't have the money to fix it and I need to fund old curse word cars Dump valve is sold. Wasn't a twin piston anyway. Turbo is the standard TD05H I need to check if the suspension is indeed Cusco or if the camber adjustable top front mounts are a seperate item to the shocks and they alone are Cusco. Not sure if I've worded that all wrong... Top mounts on the front, which are camber adjustable, have Cusco written on them for sure. Wheel's are 17" Tyres are 225/45/17. Front 2 are Avon ZZ2 and the rear's are Talon Triangles. All 4 tyres are nearly new! Open to offers. Thanks, Adam
bigkev
chillin
Hi - how much for the spoiler - I plan on chopping it about a bit mind (see the red and white Mk2)
Hmmm I'm not sure you'd want this spoiler, they do go for £100 easily
The wheels aren't STi wheels. They are gold WRX wheels and therefore won't fit over brembos. Sell them as STi wheels and you could have an angry customer on your hands STi wheels:
Last Edit: Mar 3, 2009 10:37:04 GMT by Adam
Edited
Doors, interior, front body panels all off today. Running gear suspension, wheels and brakes off tomorrow. Anybody wanting bits? Adam
Filthyjohn
Currently on the road: 1/11
^^^ 5x100 these.
'95 Volvo 945 Turbo
'87 Volvo 765 TIC
'75 Opel Manta A 2.0 16v,
'86 Volvo 360 turbo,
'62 amazon,
'67 MGB GT.
jammee
oh curse word!
hi buddy is this an import? if it isnt I'm interested in the loom and ecu probably other bits too, do you have a rough price for the turbo as its just what I'm after thanks jamie
slam it till the wheels fall off
Hi It is an import, the turbo is a TD05, Open to offers via PM Thanks, Adam
Mar 10, 2009 20:47:25 GMT
The Impreza is now in component form. Engine (EJ20) is out, HG has gone but it did run OK. Gear box is out and is - TY752VB4AA and the rear diff is a 4.11 The 4 pot brakes are off and have good discs with minimal wear Turbo is a TD05H and is off the engine. No play at the impellor atall. Bonnet is aluminium, weighs F*** all! It has a slight bend in one corner of it but I had a body shop tell me it was easily repairable by bending it and a skim of filler. I still have the wheels which are the WRX alloys with 4 nearly new tyres on them The exhaust which seems to be the original complete with what seems to be an original cat. I also have the Cusco adjustable suspension which isn't in as good condition as I was hoping so I'm not looking for as much for it. All 4 shocks have a similar amount of surface corrosion, one of the front's has a snapped stud at the top, the rear top mounts have corroded a bit and one has a slight crack in it. I also have a Toad alarm/immobilser with the green key fob. I have no idea if it's of any use to someone but I chopped off lots of loom too just incase. Adam
Mar 11, 2009 21:37:57 GMT
jammee
oh curse word!
Mar 15, 2009 20:41:46 GMT
hi mate ive pmed you about the turbo how much for the loom ecu radiator n engine cheersd jamie
