Feb 25, 2009 14:40:42 GMT
Well the Porsche 924 went in for the mot today, and it FAILED . Thankfully it was nothing major , just things like - seatbelt frayed, rear tyres different sizes, side repeater not working, fuel cap loose, fuel pipe leaking, battery not clamped, windscreen washers not working (the tester wasnt using correct switch), headlight aim on both lights, suspension bolt needs tightening, front brakes braking unevenly, and the CO level is slightly high (5.1%). Hoping to get all this fixed by next week, so I don't have to pay for another mot
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
Feb 25, 2009 14:57:16 GMT
Nothing major then... lol. CO is more than slightly high at 5.1%, should be more like 1.5% +/- 0.25, pass limit is 3.5% (which is still faulty..) And there is nothing like leaking fuel and having a nice sparky loose battery in a car with poor brakes and faulty seatbelts to really make you feel glad you are still alive
Feb 25, 2009 14:59:31 GMT
LOL, nice safe car by all accounts. Did you just bosh it in without checking it?
Feb 25, 2009 15:04:55 GMT
What sizes was the rear tyres then?
Feb 25, 2009 15:09:40 GMT
;D driving that home must really have got the adrenaline flowing!
Feb 25, 2009 15:24:34 GMT
What sizes was the rear tyres then? 1 x 165/70 14 1 x 145R10 (mini wheel)
Feb 25, 2009 15:29:16 GMT
What sizes was the rear tyres then? 1 x 165/70 14 1 x 145R10 (mini wheel) ;D ;D
Feb 25, 2009 17:19:06 GMT
Gave the car a good check over, but the things it failed on are not that bad, like the tyres are a 165/65R14 and a 165/70R14 (obviously illegal, but not quite as bad as xbo11ox suggests ). Also the battery is clamped in, but the clamp hasnt been fully tightened. The petrol cap tightens on, but doesnt lock, and the fuel leak is minimal (wasnt there prior to the test). Little update - got a pair of seatbelts off a 16000 miler 924S in a local scrapyard today,
Feb 25, 2009 17:59:20 GMT
Well the Porsche 924 went in for the mot today, and it FAILED . Thankfully it was nothing major , just things like - seatbelt frayed, rear tyres different sizes, side repeater not working, fuel cap loose, fuel pipe leaking, battery not clamped, windscreen washers not working (the tester wasnt using correct switch), headlight aim on both lights, suspension bolt needs tightening, front brakes braking unevenly, and the CO level is slightly high (5.1%). Hoping to get all this fixed by next week, so I don't have to pay for another mot U could have crossed most of that off by taking it to my local MOT tester, u'd have only failed on side repeater not working, fuel cap loose, fuel pipe leaking, headlight aim on both lights! ;D Blind as a bat! In a good way
Feb 25, 2009 18:18:24 GMT
Well, fix the bits and get driving.
jikovron
mechanical chaos
Feb 25, 2009 19:43:43 GMT
the emissions arent too bad considering the car hadnt run on the road for 9 months,,,,swop the spare wheel on,(it must be similar to at least one of the rear wheels)
ohh and the advisories,,,were there many
Last Edit: Feb 25, 2009 19:46:47 GMT by jikovron
Feb 25, 2009 20:13:24 GMT
I'll help ya on friday mornin' if ya wish. Most of them are really easy fixes, just the headlight alignment that could prove tricky
'67 Vauxhall Viva HB Deluxe
Feb 25, 2009 20:20:13 GMT
the emissions arent too bad considering the car hadnt run on the road for 9 months yes they are.. over 5% CO on a K jet car means its faulty no way should it be that high regardless of how long it has stood. On the plus side tho, its normally only the warmup regulator. Don't play with the metering head or the volume screw until you have eliminated it as cause.
Feb 25, 2009 20:25:28 GMT
Ron, i think those are the only things wrong, as he didnt say anything about advisories : :. The side repeater is fixed (loose connection), the seatbelts and petrol cap are bought and ready to put in, the spare wheel has been put on so the rear tyres are now the same size, the battery will be clamped up properly, and the bolt will be tightened. So that just leaves - the CO level, the headlight aim, the front brakes, and the petrol leak
Feb 25, 2009 20:31:53 GMT
Well the Porsche 924 went in for the mot today, and it FAILED . Thankfully it was nothing major , just things like - seatbelt frayed, rear tyres different sizes, side repeater not working, fuel cap loose, fuel pipe leaking, battery not clamped, windscreen washers not working (the tester wasnt using correct switch), headlight aim on both lights, suspension bolt needs tightening, front brakes braking unevenly, and the CO level is slightly high (5.1%). Hoping to get all this fixed by next week, so I don't have to pay for another mot U could have crossed most of that off by taking it to my local MOT tester, u'd have only failed on side repeater not working, fuel cap loose, fuel pipe leaking, headlight aim on both lights! ;D Blind as a bat! In a good way How excactly is that good?
Feb 25, 2009 20:37:41 GMT
:)Why did the unclamped battery fail? How is it worded on the VT30?
Feb 25, 2009 21:09:21 GMT
as a rough guide for checking headlamp aim - park 10 meters away from a wall, on flat ground. Measure the height from the road to the centre of the headlight and subtract 10cm. Mark this new height on the wall. The horizontal section of the beam should be set to this height. The beam should also kick up 30degrees or so to the side. The point where this kicks up should be directly infront of each light - measure between centres of your headlights, then measure between the two kick-up points on the wall and check they are the same distance.
ezzysi
Feb 25, 2009 22:42:58 GMT
1991 Mk2 Golf Gti 8v 2005 Passat tdi (daily) 1971 Mk1 Escort 2004 Touran (her's)
deejay
WELSH DRAGGIN'
Feb 25, 2009 23:17:19 GMT
:)Why did the unclamped battery fail? How is it worded on the VT30? Exactly what i was wondering... Loose battery is NOT a fail, it can only be advised!
Feb 25, 2009 23:54:44 GMT
:)Why did the unclamped battery fail? How is it worded on the VT30? Exactly what I was wondering... Loose battery is NOT a fail, it can only be advised! depends how loose I suppose... If its dangling by its straps 3" off the road it might come under "general vehicle condition" oh yeah, and another handy hint... make sure the lights pop up to the same point each time you use them before doing the aim as per above..
