haggis
Jan 21, 2009 23:40:27 GMT
Megasquirt MS1 V3 with EDIS, loom and leads for ford rs2000 engine it is MS1 V3, has base map for i4 engine loaded. ecu has the built in map sensor aswell. new cable from laptop to ecu and a usb adaptor for it. also has the edis 4 module, wiring, coilpack. I will even chuck in spare wiring,connectors that I have from when I made my loom. been tested on a simulator and works perfectly. Subaru Impreza or Legacy TD04 turbo. Was my spare from my old wrx. don't have it anymore so I don't need it! Low mileage, no play in shaft and generally in very good condition. cost me £175 last year, grab a bargain! Up for sale is a Blue Samco Top Boost hose and dump valve for an Escort RS Turbo probably will fit a fiesta as well. very good condition all round, grab a bargain on price new! Had these machined in stainless steel so I could make my own turbo manifold for td04's or td05's cost a small fortune to get done. would be ideal for someone carrying out a home grown turbo conversion all on ebay shop.ebay.co.uk/merchant/marinepower* ( please insert the asterisk after marine power)
Last Edit: Jan 22, 2009 10:48:05 GMT by haggis
haggis
Jan 21, 2009 23:41:01 GMT
Megasquirt MS1 V3 with EDIS, loom and leads for ford rs2000 engine it is MS1 V3, has base map for i4 engine loaded. ecu has the built in map sensor aswell. new cable from laptop to ecu and a usb adaptor for it. also has the edis 4 module, wiring, coilpack. I will even chuck in spare wiring,connectors that I have from when I made my loom. been tested on a simulator and works perfectly. Subaru Impreza or Legacy TD04 turbo. Was my spare from my old wrx. don't have it anymore so I don't need it! Low mileage, no play in shaft and generally in very good condition. cost me £175 last year, grab a bargain! Up for sale is a Blue Samco Top Boost hose and dump valve for an Escort RS Turbo probably will fit a fiesta as well. very good condition all round, grab a bargain on price new! Had these machined in stainless steel so I could make my own turbo manifold for td04's or td05's cost a small fortune to get done. would be ideal for someone carrying out a home grown turbo conversion all on ebay shop.ebay.co.uk/merchant/marinepower*(Please insert the asterisk after marine power!)
Last Edit: Jan 22, 2009 10:47:22 GMT by haggis
bruisercapri
black and blue and black all over
checked ebay, apparently there's nothing for sale i'm interested in the megasquirt is it still available?
haggis
Jan 22, 2009 10:39:51 GMT
bruisercapri
Jan 22, 2009 21:07:28 GMT
thats got it, watching ;D open to offers?
haggis
Jan 22, 2009 23:22:37 GMT
yes if over than the starting bid!
