i'm having a bit of a clear out!
for the K10 Nissan Micra I have:
Spax -35mm Lowering Springs (full set front and rear) £30
a full head gasket set for the 1.0l £5
For the Triumph Dolomite I have:
Rimmer Bros -1" 175lb uprated lowering springs (fronts only) i brought these for my Toledo but they didn't do any lowering I i presume they will only make a height difference on the heaver Dolly Sprint and 1850. They are certainly much stiffer then the standard springs. These are effectively new as they were only fitted to my car for 10mins ;D £30
lower wishbone arm with bush fitted - metal type
www.rimmerbros.co.uk/dolomite/images/24c.gif
part UKC1698. This was fitted to my car for about 2000miles the car is now polybushed. £5
Prices are open to negotiation, i haven't put postage prices but i suspect the springs will be over £10 as they are quite heavy.
cheers Mat
cheers Mat
