Dec 28, 2008 21:54:31 GMT
Ive got my Audi 100 up and running after changing the head but cant seem to set it up properly. The dizzy needs timing up and the carburettor needs fettling. I have to confess that ive never done "tuning" before... Ive always left it to someone else to do!
Is there anyone near Stoke on Trent who can help out in exchange for beer tokens?
The engine is an 1800cc 8V 4 cylinder Volkswagen engine with a Keihin carb. At the moment theres flat spots and spluttering. Very annoying....
Can anyone help/advise?
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
Dec 28, 2008 22:04:19 GMT
keihin? Isnt that a japanese carb? My 1800 audi (80) had a pierberg which was nasty, and caused all sorts of amusing vacuum related trouble until I binned it and fitted digifant II off a golf GTI instead. Oh yeah, and the rubber isolating block/gasket splits, lets in air and eventually makes the carb fall off entirely. A new one was gonna cost more than the donor golf did, and that was 10 years ago.
Dec 28, 2008 22:43:09 GMT
I work in stoke so might be able to help, have you got any info on the engines like a haynes manwell etc. I had my manta tuned at a garage because i was fed up with getting it wrong but didnt stop me trying!!
1987 Opel manta GT 2.0 16v 1976 Opel manta s project 1985 Opel Rekord E 2.2i 1992 Vauxhall Carlton 2.3TD 1989 Mercury Grand Marquis 2005 Landrover discovery 3
Dec 28, 2008 22:58:26 GMT
I robbed the carb from an audi 80S from the local breakers. I thought it was a pierburg but after looking at the haynes manual its either a keihin or a pierburg as those are the only ones fitted to this model. Its deffo not a pierburg so it must be a keihin... It looks like a keihin atleast. Id never heard of them until I looked in the manual!
Ive got the handbook and a haynes manual so should have all the info needed.
Surely fitting the injection system from a gold GTI would be an unfeasibly huge amount of work?
Last Edit: Dec 28, 2008 23:00:18 GMT by Lankytim
Dec 28, 2008 23:12:46 GMT
news to me then. I've never seen a keihin on a VAG. plenty on hondas Fitting the injection was easy... I had to change the head for the inj one, but you already did this.... after that its jsut manifold, AFM and injectors (with the sub-loom and control box, of course) and the golf's pump/swirl pot cable tied in front of the tank. took me about an hour and a half ;D
Dec 28, 2008 23:21:34 GMT
Damn, I wish id known that before I filled the injector holes with araldite!
I'm starting to hate old cars!
