Jul 23, 2005 17:08:36 GMT
I'm popping a Cooper engine into an Allegro (Yeah I know its probobly a waste!) anyway, Its got no carbs or manifold but I have been got an SU HS4 on the combined carb/exhaust manifold from the original 1275 engine. Also been given a HIF44 with the same sort of combined manifold. Is this HIF44 of an MG metro? What difference would a heated manifold and maniflow exhaust manifold/downpipe make? IF I were to compare both carbs on the engine which would produce better performance and why? Thanks.
If its lonely, brown and crusty. I'll love it, modify it, then kill it!
Jul 23, 2005 17:32:44 GMT
Hi there Sounds like an interesting combination, would a metro turbo engine fit?? a whistling popping allegro Well the HS4 is a 1.5" and the hif44 is a 1.75" i think, the heated manifold is only really there to help with low speed running. But the exhaust will make a difference for sure. Will a mini manifold one fit thye allegro chassis? cheers J
Jul 23, 2005 21:03:09 GMT
Just a little side note... HS carbs have external float chambers, whereas HIFs have internal (IF stands for Internal Float) Hope I ain't stating the bleedin' obvious there!
slater
Club RR Member Number: 78
I assume you are fitting a 1275cc cooper engine? if its on a standard cam then stick with a 1.5" carb as you will gat alot more midrange power (good for the road) HIF44s are great carbs but are best suited to bigger bore engines like 1380s or racing 1275s/1098s etc. Best to get the exhaust And yes a metro turbo lump will fit
HIF44 is standard kit for any 1275 A+ engine AFAIK.
Yeah, as far as i can tell its a standard 1275cc cooper engine as bought from a bloke out the paper. The Allegro already has a 1275cc lump, but I thought the cooper one could be more entertaining especially as the car has a top speed of 77mph... D'oh.
So you say I should setup the HS4 for this engine rather than the HIF44? What about carb needles?
I know the theory about the LCB system, that the centre branch should be twice as long as the side branches, but does it make a noticable difference? The cooper manifold is just three slightly longer branches over standard joining at the same point to a central downpipe.
I'm hoping that mini downpipes will fit the allegro shell, their seems to be plenty of room of adjustment if necesary and I think the servo is well out the way, Its just trial and error. Not many companies stock performance parts for a 78' Allegro! ;D
slater
So you say I should setup the HS4 for this engine rather than the HIF44? What about carb needles? Yeh thats what id say, The HIF will give you a higher peak power to brag about ot your mates max power stylee but the HS4 is a better carb for road use ads you get better mid range. Athough the HIF does have other advantages such as less fuel surge problems so its not a bad choice. Also the HIF isnt standard fitment on a cooper (I'm assuming you men 60s cooper not a modern injection one?)
HIF44 is standard fitment on the later carb Cooper and MG Metro`s !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I know, I`ve got one !!!!!!!
