Apr 30, 2009 12:35:04 GMT
Ahh I see, sounds like a barrel-load of oily fun!
Good stuff with the exhaust stud too - that was frustrating you last afternoon from what I could tell.
I'm hoping I've plumbed the fuel lines right as it was a bit of a head-scratcher hahah
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
Apr 30, 2009 18:34:31 GMT
as long as you didnt do what i did when pheonixc and i converted the carlton to efi.
i didnt really fit the tank sender back in upside down.........did i?
yep
doofus ;D ;D
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Apr 30, 2009 18:40:37 GMT
Sterling work Beastmaster and Datman, hey that sounds like a new crime fighting duo! maybe that should read Grime fighting duo ;D
Apr 30, 2009 18:48:28 GMT
Yeh, from the UK, cost 79.99 Cool,that's good value! Is there a specific p/n you need to quote for them? Yeh, you can only get them with the part numbers - which can be supplied via PM if required. PM-only as I'm sure stocks are low and wouldnt want them blitzed
Apr 30, 2009 20:37:51 GMT
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
Apr 30, 2009 20:52:08 GMT
i reckon take 2 coils off it and put it back!!!! LOL
yes ,it started badly ,petered off in the middle and the least said about the end the better!!!
Apr 30, 2009 20:56:11 GMT
Bloody hell! what the hell is a spring doing in there!!? Cant have been doing it any favours I see the difference between the sumps now
Apr 30, 2009 21:20:19 GMT
engine is bolted in, and done some of the wiring. Had to modify throttle linkage. but power steering pipes don't fit, went to hydraulic shop and they don't have anything to suit unless I get the original pipes lengthened in the middle. Probably gonna have to go that route. Still got to do the heater pipes, and exhaust. Tried the zx front pipe on, but it hits the steering. grr. Gonna be a three dayer this one! Amazing how much was different in the end, trans switch, engine and trans mounts, alternator, exhaust, throttle, PAS, sumps, heater connections, and if course wiring and fuel / air system.
Last Edit: Apr 30, 2009 21:22:26 GMT by datman
Apr 30, 2009 22:16:25 GMT
props to datman
2001 HONDA CT110 (NOT RCV)
Blimey! Lots gone on yesterday then. Thats a curse word about the PAS hoses Could've been a lot worse though I guess as its mainly just the relocation of things.
i remember when you bought this, and i thought i had read the readers rides ... but clearly not!
I had no idea what was going on! Massive pat on the back from me mate for making such good progress, and keeping it moving on whether that be by getting stuck in or getting others involved to help!
i really cannot wait to see this up close - possibly my most anticipated car of the year in fact.
BTW - black rocks! Its why my bug is black, cos when its right there it NOTHING better! For some reason i think your ride can pull off most colours, as long as the associated detailing is right. I could see a burnt orange on it, candy red, or even something like audi nimbus grey.
BIG THUMBS UP FROM ME DUDE!!
cheers keefy. Its certainly been a steep learning curve with this one as I'm trying to do as much as I can myself, but its good fun - if hard work lol As for colour, its just gonna get a blow-over in something in a week or two to tidy it up/protect it. I'm mainly looking forward to being able to use it properly as its been too unreliable, but the new engine will sort that
burger.. the starter doesn't fit either. which is a pain since your old one is dodgy.
burger.. the starter doesn't fit either. which is a pain since your old one is dodgy. oh ffs Didnt you say before (when i was first having troubles with the starter) that you had others in 'stock'? Could swap the good 280ZX one for an appropriate one? Failing that, just use the old starter... it does work most times but mostly plays up when the engine doesnt like to start - which hopefully wont be a problem with this new one seeing as it used to start on the button?
new ones in stock yes but i've found a used one which I will test tomorrow.
Last Edit: May 1, 2009 16:45:14 GMT by datman
new ones in stock yes but i've found a used one which I will test tomorrow. Awesome
What sort of power increase are you looking at Johnny?
What sort of power increase are you looking at Johnny? I'm not sure really... maybe 30bhp? The plate under the hood of the Cedric says 139bhp and online I've found 280ZXs listed at around 170 (depending where you look) I'm not fussed about the power anyhow - its just a bonus reallt
Johnny, I can do the Power Steering hoses, tell me what you need and I can make em up!
Ooh. pipes are correct fitting but are about 3 inches too short due to different pump location. Box end are both banjo hoops . Pump is a big thread , and a 3/8 slip joint (ordinary hose clip) for the return.
Last Edit: May 2, 2009 19:44:59 GMT by datman
