Oct 27, 2008 17:15:48 GMT
Quick question: I've got me eyes on a set of wheels for my GT but the owner says they don't hold air for more than a couple of days without inner tubes. If the alloy is pourous, do you thinnk the wheels are safe? ![???](//storage.proboards.com/forum/images/smiley/huh.png)
Oct 27, 2008 17:18:05 GMT
Depends how cheap they are i suppose, i had the same thing with my old Mini alloys, the tyre shop cleaned up the rims with the tyres off, then used the glue stuff and it stopped them leaking.
Hope thats of some help!
OAP drifta Volvo 340,Williams power 1960 Beetle twin 40's 1776cc
Oct 27, 2008 17:20:12 GMT
No wheels for ADO16s are cheap ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png) The leaking doesn't bother me, I'm happy using tubes its the safety that concerns me a little
Brigsy
Oct 27, 2008 17:21:07 GMT
They probably just need the insides of the rim cleaning up, get them shotblasted & powdercoated.
Oct 27, 2008 17:25:59 GMT
What they said.
I had this issue with the KN Jupiters on my old Estelle. Did as per Brigsy's advice, sorted.
Oct 27, 2008 17:27:04 GMT
Cheers guys A shall make them mine ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Oct 27, 2008 19:54:12 GMT
the surface of the alloy can corrode around were the tyre seats,bit sandpaper and they should be fine.as for the safety i cant see a problem.
The wheel can also become porous as your seller has told you, I have this with a set of Cosmic alloys on my Mini. I have autotested and done historic rallies with tubes in with no problems and no concerns.
These were definately leaking through the wheel, not at the tyre bead.
Russell
g40jon
Oct 28, 2008 10:24:51 GMT
a good test if a wheel is good, is that it should make a nice ringing sould when tapped with something reasonble hard in the same way a bell rings when its struck (this isnt a 100% perfect way of telling, but it does give a good indication) but as already said its often just the bead that leaks
Mr K
Oct 28, 2008 10:35:15 GMT
a good test if a wheel is good, is that it should make a nice ringing sould when tapped with something reasonble hard in the same way a bell rings when its struck (this isnt a 100% perfect way of telling, but it does give a good indication) but as already said its often just the bead that leaks that will tell you if its cracked - not if its porus AFAIK.
Nathan
Club RR Member Number: 1
Buying Old Alloy WheelsNathan
@bgtmidget7476
Club Retro Rides Member 1
Oct 28, 2008 11:50:46 GMT
Lick'em, if your tongue goes dry they are porus ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Oct 28, 2008 13:16:16 GMT
Lick'em, if your tongue goes dry they are porus ![;)](//storage.proboards.com/forum/images/smiley/wink.png) GENIUS! ;D
Oct 28, 2008 18:16:00 GMT
Give em a sandblast and a splash of paint before licking em otherwise you won't get a good seal on your tongue.
Oct 28, 2008 18:48:15 GMT
all the KN wheels go that way eventually i painted them and ran tubes and hardslam and they never even hinted at exploding. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
