right, take 1 mk1 golf cab and add imagination. ;D what can you's lot suggest for this innocent looking cab? before anyone suggests it i have some adjustable coilovers to sort out the on stilts stance
Big blinging chrome wheels and a raked stance??
wide euro rims with streched rubber.
slammed and chrome bumpers and nice phat chrome zorst!
if it aint mini then it aint a mini.
remove windscreen, and roof, and put some 4x4 tryes on it, and lift it uyp a few '
schmidts / ronal turbo's.
Front so low it can't get over a rizla. Back a lil' higher.
Single light front (I assume it has twins?) Battleship grey primer (with one white door and a wing in red oxide) Suitably "distressed" hood.
Remove all extranious trim and replace as necessary with iron cross door mirrors etc.
1-8T jengine from current VAG range. Chromed where applicable. All "unneccessary" items (washer bottle, wiring etc) removed from bay and "hidden".
Job done. Respect Due.
Job Done.
Big blinging chrome wheels and a raked stance?? thought about that but don't want to stand out now do i??
How about,... Make it as smoooooooth as possible. door handles, petrol filler, repeater etc. etc. But also that lower body line/seam, single piece windows, bumper. Find some alternative rear lights and recess them into the bumper (horizontally) then smooth off the whole of the rear... Airbags/hydros + 13 or 14" Wire wheels ,.. A bit like a Golf version of this : retrorides.proboards29.com/index.cgi?board=readersrides&action=display&thread=1120070243
def ronal turbo's stretched rubber, and supa slammed. If it was a saloon the i would say go for the mega wide arches and fully stripped. But as its a cab go for smooth as previously posted.
J
том
"If in doubt, flat out!"
Last Edit: Jul 4, 2005 19:29:43 GMT by том
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Nice idea smoothing the dash/interior as well.. would be perfect as its a cab so your more likely to see it
really liking this, wonder how it would translate?
don't have white bands on if your leaving it white, (a bit much i think,works better with colour) and it should look pretty cool
just seen some redband tyres
том
very groovy, lovin the wheels, not so keen on the door handles though or the union jack on the roof, less is more and all that
The trick with a good custom/modifying job is to pick your theme and stick to it. A lot of cars get build with one idea in mind, but then over egg the pudding by adding in too many influences. So if you choose your styles, cal-look-lowrider, or Hermanlook-offroader ,.. or whatever! Make sure you assemble your ideas and stick to them. That Red golf is almost perfect, but I think the chrome under the door handles and the roof union jack have aver egged it. A little more restraint would have been spot on. So my theme for your car (as you already have most of it in place) is black and white. I shall photoshop when I get them time
i had come to the same conclusion of black and white. so far i have come up with single lamp grill, bumpers back to black, remove side trim and dropped on its on black steels with whitewalls, no idea what style you would call it but in my mind it works (and in the really rough photoshop i did too) ;D
black steels with whitewalls sounds cool, what size steels you thinking of? I've got 5 13" steel rims off a Skoda Felicia that should fit or are you going 15"?
Current Fleet 2006 Skoda Roomster 1.4 16v (Daily) 1990 Autozam Revue 1.5 Auto Canvas Top (Project) 1993 VW Transporter LWB 2.4D (Camper Project) 1994 Skoda Favorit Foreman II Pick Up (Project) 1979 Skoda Estelle 120LS. (Project) 1982 Kip Kompakt 300 Caravan (Project)
no idea what style you would call it This is evern better than mixing up styles ...
black steels with whitewalls sounds cool, what size steels you thinking of? I've got 5 13" steel rims off a Skoda Felicia that should fit or are you going 15"? i think 13's might be a tad too small, but not sure i'll have to find some pics of golfs with them on to make an informed decision
No ones mentioned Lambo doors yet ?!
