I am selling 4 x Rostyles. They all have tyres with plenty of tread (3 of which are still 8mm (pretty much new) and one has 5-6mm). The final tyre has cracks in it (an India GT tyre), hence depending on your tester, it may or may not pass (no beads etc. showing, but I would replace it). £60 for the 4 will take them away. They were refurbished back in 2000 on the front and back. While there some tiny specs of rust here and there on them, it's surface and wire wool with a little touch up will keep them looking great. A 5th original (un refurbished) rostyle can be included for another £10 or you can swap me one Minilite (14" or 15") made to fit an MGB .
MG Midget Trunion Bushes. New and ready to go. Price of postage will take these.
MG Midget brake slave cylinder rebuild kit x2. This can circumvent the need to take your cylinders off (which can be difficult on a Midget with its dual backplate design (involves taking the hub off of the rear), and these are unused. I wish I knew I had them when I did the Midget's rear brakes! Again, as above, price of postage will cover these.
I am also selling a Ford Coilpack from a Focus 1.6. We replaced this thinking that it was at fault, except the RAC man got it wrong (new coilpack, and still no better, turned out to be a crank sensor). It is around 2 years old, and it is a FoMoCo (Genuine) item with no corrosion at the plugs or marks at the bottom, hence ready to go £10.
Also under the hammer is a K&N panel filter from a 1.6 Focus. This is in good condition, and again is ready to be shifted on. £10 collected, £15 with delivery. This I am willing to swap with an air element (Pipercross/K&N etc.) for one from a Peugeot 205/309/306 GTi-6 and D Turbo).
I am also selling a Pipercross induction kit for a 306 GTi-6, which will fit the D Turbo. This is in very good condition, and was cleaned and reoiled around 4 months ago. This comes with the bracket and can probably fit many other cars (filter neck is 73mm). £25.
Jaguar XJ40/XJ6 intrustment control panel around the steering cowl is also for sale. Unlike many, this has zero wear to the writing and can spuce up a tired XJ40 interior. This *may* fit the X300 but you would need to research that, £5 or it goes in the tip.
Also for sale is a VRX 10" subwoofer in the box (0.64 Cu Ft sealed) in perfect working order. £15.
Pics I will put up later on.
