Obviously the oil cooler is for the autobox but hte top spec granny cosworth has a seperate cooler aswell as the one built into the radiator. The cooler sits horizontaly at the base of the radiator.
Does anyone know if it is thermostaticaly controlled? I'm presently breaking one of these cars (engine going into my Cortina for now, then who knows, old TVR? Scimitar?) and thought I may aswell get every usefull bit off it. I probably won't need an oil cooler for the 'tina but who knows what the next project will be. Hence I'm removing the front and rear calipers, cruise control, air-con etc...
Cheers for any help.
Smiler.
Smiler.
